Author Topic: Project Update and Suspension Help  (Read 1757 times)
Offline CBR954AD
« on: June 19, 2015, 09:37:07 AM »
Good Morning CB lovers,
So it has been about 4 months since I posted something on here. i wanted to give an update for my project and I have few questions.
UPDATE:
Frame Painted
Swing Arm painted
Front Rear Wheels laced and trued
Forks rebuild and painted
Questions:
I need Rear Shocks!!
I am running a 78 GL1000 front end with the 19' wheel and a CB750 rear wheel 18'.
what length shock do I need for this setup? when I look up shocks there is different lengths like from 11 to 14 inch.
Will these work for my setup?
http://www.amazon.com/Progressive-Suspension-12-1204B-Powder-Pressure/dp/B000GUWO8K/ref=au_as_r?_encoding=UTF8&Make=Honda%7C59&Model=CB650%7C17049&Year=1979%7C1979&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=1&vehicleType=motorcycle
I will post pix of project later on today. Im on the hunt for shocks right now. I need to order asap
« Last Edit: June 19, 2015, 09:39:03 AM by CBR954AD »
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Project Update and Suspension Help
« Reply #1 on: June 19, 2015, 10:55:37 AM »
You should start a thread in the projects forum! Keeps it all in one place for easy reference later.
Are you using the stock swingarm with stock shocks? How much taller is your front end now, compared to stock? For best handling, you'll want to match fork angles as close to stock as possible, which may involve using longer than stock shocks.
Those shocks will not work. You need a clevis on the bottom of the shock, not an eye. Look for "eye to clevis shocks". Check out Hagon, etc..
--Evan
1975 CB750K "Rhonda"
Offline CBR954AD
« Reply #2 on: June 19, 2015, 11:02:05 AM »
yes I am using stock Cb 650 swing arm and i have my stock shocks but i would like to upgrade to shocks w reservoir on em or progressive shock. the fork length is the same as the 650 only difference is fork are thicker. I do not know how to get the rest of the measurements that u are asking for?
These are made for my bike
http://www.amazon.com/Progressive-Suspension-12-1204B-Powder-Pressure/dp/B000GUWO8K/ref=sr_1_1?s=automotive&ie=UTF8&qid=1434736744&vehicle=1979-59-17049-20-----14115------1-0&sr=1-1&ymm=1979%3Ahonda%3Acb650&pebp=1434736753415&perid=1NVP4Y82P19CTQ12XCRB
« Reply #3 on: June 19, 2015, 11:29:44 AM »
Sorry, but Amazon is NOT always correct about fitment. You will need an eye to clevis shock for 1979-82 CB650 models.  The ones pictured are eye to eye.  MORE IMPORTANTLY, they don't come with springs.  I'm sure you'd rather have pre-assembled shocks.
Also, DO NOT buy cheap Chinese crap, even IF it has a reservoir.  If you buy cheap shocks, you will get a cheap, crappy ride.  If you are set on Progressive BRAND shocks, call them and get the correct 12 series model for fitment for your bike.  You should also look into Hagons, IKONS, or if you want quality reservoir shocks WORKS or RACE TECH.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #4 on: June 19, 2015, 03:38:41 PM »
CBR954AD,
If you are at all interested in looking at Ikon shocks, send an email to
Ikon Suspension USA <ikonusa@gmail.com>
The person that gets the email is Dave Gardner, and he is good about talking you through the details of what you are looking for.
Charlie
