Author Topic: Backfire and flames on startup 76 cb750  (Read 2053 times)
Offline Cb^_^750
« on: June 18, 2015, 06:52:52 PM »
I recently took my engine apart to re do the gearing in the lower case. But now it's seems that it doesn't want to start. When it cranks I get popping sounds and with the pods off I've seen flames come out the carbs. Is this a timing issue? I don't see any other possible reason I re assembled the bike exactly how I took it apart. Any idea on what it could be or possible fixes? It's feeling like I'm never going to see the light at the end of this tunnel
Offline goldarrow
  • one day, i'll be an
Re: Backfire and flames on startup 76 cb750
« Reply #1 on: June 18, 2015, 07:25:36 PM »
Ignition timing, try to swap the blue and yellow wires
CB550 K0
Offline rb550four
« Reply #2 on: June 18, 2015, 07:45:25 PM »
+1 on ignition timing. Check your points for gap, condition and firing time. Not everything went together the way it was.
Just need to back track and double check .
« Reply #3 on: June 19, 2015, 02:54:19 AM »
+2 on ignition. If you have taken the advancer unit apart you might have mounted the rotor wrong so you must connect base plate wires with main harness, yellow wire with blue and vice versa to get it running.
Also possible if you have connected spark plug wires the other way. 1-4 to coil 2-3...... If you have changed coils+ wires. Std coils with wires still on not possible when 1-4 are much longer.
« Last Edit: June 19, 2015, 02:56:24 AM by PeWe »
Offline Cb^_^750
« Reply #4 on: June 19, 2015, 07:42:20 AM »
So you are saying the wiring coming from the advancer got mixed? The red goes to red and black to black. Then there is green but those go to the yellow and blue from the coils?
« Reply #5 on: June 19, 2015, 07:58:46 AM »
Your points plate probably has shifted from where it was previously.
Set your points gap .014" when fully open
Offline Cb^_^750
« Reply #6 on: June 19, 2015, 08:30:29 AM »
I had never touched my points or messed with them but I will double check when I get off work
« Reply #7 on: June 19, 2015, 08:34:01 AM »
you had to take the points plate and advancer unit off to do your bottom end work, right?  ::)
it probably shifted from where it 'was' and has thrown your timing off...
« Last Edit: June 19, 2015, 08:39:22 AM by flybox1 »
Offline goldarrow
« Reply #8 on: June 19, 2015, 09:08:28 AM »
I don't recall stock oem points have red and black wires
CB550 K0
Offline Davez134
« Reply #9 on: June 19, 2015, 09:57:58 AM »
The red, black, green sounds like wiring from pamco ignition
Offline Cb^_^750
« Reply #10 on: June 19, 2015, 02:19:34 PM »
Yeah looking at the wiring diagram my wire colors don't match up. Previous owner must've changed it but the bike was running before and I had wired it up just like it previously was. I'm about to take a look at the points right now.
Offline Cb^_^750
« Reply #11 on: June 19, 2015, 06:57:43 PM »
I managed to get th bike fired up. Turns out two wires were crossed. But only after a minute of idling the bike was puttering and shut off. Checked plugs and there were darker than night. Assuming running to rich? Or timing is to far advanced?
Offline chewbacca5000
  • I polish covers!
« Reply #12 on: June 19, 2015, 07:13:18 PM »
Pull plug and clean with carb and blow off with compressed air and try again.  As for color they would be black after all that.  Have you done the 3,000 mile tune up?
Offline Cb^_^750
« Reply #13 on: June 19, 2015, 10:35:11 PM »
No I have not I'm fairly new to the bike word. Enlighten me
