Author Topic: Battery ignition without alternator  (Read 2142 times)
Offline Aurel
« on: June 19, 2015, 12:10:40 pm »
Hi,
At the moment i have an ARD magneto on my race bike but i want change to a  dyno 2000 ignition.
I have no alternator on my bike, i want drive with battery. How  many Ah did the battery need that i can drive 1,5 hours or so.
Many thanks in advance
Offline Old Scrambler
Re: Battery ignition without alternator
« Reply #1 on: June 20, 2015, 02:24:46 pm »
Get a good quality Liitium+ with a 9Ah rating. It will hold steady power for a long time.........how long, I don't know. But I have run a total of an hour or slightly more on a total loss ignition without a recharge. Because of their smaller size and light weight, you may want to install two units for an even longer life. I personally like the Deltron brand (Battery Tender) because they have 4 posts and can be recharged at a 10Ah-rate.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: June 20, 2015, 02:32:48 pm »
For a while I used a Dyna 2000 system running total loss with an 8 cell LithIon and it would power it 30 minutes at best. The ign. unit had issues so I'm not sure if mine used more power than other D2K's. With a different ignition I gained 15 minutes run time.
Not much help sorry, but by my experience even a 16 cell LiPo would only give an hour.
Offline Aurel
« Reply #3 on: June 23, 2015, 10:21:19 am »
Thanks for the comments.
A friend of mine uses a dyna S with a 4Ah battery and he can drive 2 hours or so did the dyna 2000 need that much more power??
« Last Edit: June 23, 2015, 10:23:20 am by Aurel »
« Reply #4 on: June 23, 2015, 11:58:21 am »
Good Question...............Mine was a Dyna S on 9Ah Lithium on one bike and a adapted GM system on another that ran on a 1Ah Lithium that we suspect lacked enough power for a good spark at high rpms...............however, iridium plugs only need about 50 - 60% of the power to spark when compared to a conventional plug.  This year I am using a Deltran 9Ah (Battery Tender) battery hoping to have an even longer life with 4-posts for versatility, and improved charging characteristics.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #5 on: June 23, 2015, 12:54:28 pm »
Is it apace or weight problem.?
We could usually. Run points for 1.5 hours or more using just a small 5.5 Ah battery
My understanding. Is the electronic ignition need like 10.5 ish volts to stay running.
 Maybe you just need a bigger battery..
Offline voxonda
« Reply #6 on: June 23, 2015, 01:10:49 pm »
Dyna needs high(-er) voltage (10.5 - 11) to keep running. My current Accent keeps running until it drops to 7V.
« Reply #7 on: June 23, 2015, 01:55:23 pm »
 How do the newer type batteries hold up compared to lead acid  ?
Offline turboguzzi
« Reply #8 on: June 23, 2015, 03:40:25 pm »
Aurel, maybe introduce yourself, show your bike, etc.... could be nice :)
i run both my 4 cylinder race bikes with oem ignition modules off 90's bikes (GSXR750 in my case) and with the gsxr coils i get about 1-1.5 hours out of a 2.4 AH battery
it's quite easy to calculate, you just need to run you bike and measure the current consumption, then multiply by the time in hours, youll get the Ah you need. in order to avoid voltage drop, woud take a battery thats double that capacity. i.e. if your ign consumes 1 amp and you want to be able to run 1.5 hours, would take at least 3 - 4 Ah. batt
« Reply #9 on: June 23, 2015, 03:49:30 pm »
I GOOGLED THIS..........
TheĀ­ three most basic units in electricity are voltage (V), current (I, uppercase "i") and resistance (r). Voltage is measured in volts, current is measured in amps and resistance is measured in ohms.
A neat analogy to help understand these terms is a system of plumbing pipes. The voltage is equivalent to the water pressure, the current is equivalent to the flow rate, and the resistance is like the pipe size.
There is a basic equation in electrical engineering that states how the three terms relate. It says that the current is equal to the voltage divided by the resistance.
I always preferred wrenches over wires.........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline Aurel
« Reply #10 on: June 25, 2015, 12:15:54 pm »
i ASK DYNATEK AND HE TOLD ME THAT THE DYNA S AND THE 2000 CAN DRAW UP TO 8 AMPS WITH THE 3 OHM COILS.
Offline bear
  • Leeton in Australia
« Reply #11 on: June 25, 2015, 04:53:06 pm »
Sorry this is a little off topic, but might be of intrest to some.
A number of speedway chairs down here have been using 18 volt lithium drill batteries.
Apparently it works quite well for their application.
Brian
Offline BPellerine
« Reply #12 on: June 25, 2015, 04:57:36 pm »
sorry if this question is being asked again but why do you want to change?no advance?
1978 CB 750K ard and webers
another anfob
« Reply #13 on: June 25, 2015, 09:24:10 pm »
Bear I make my own from 36V Dewalt batteries, or used to while they were cheap.
Offline Aurel
« Reply #14 on: June 27, 2015, 10:48:42 am »
with new ignition is better to speed up when you have a adanced ignition time
Offline BPellerine
« Reply #15 on: June 27, 2015, 04:01:48 pm »
that is what I thought,coming out of slow corners harder with the ard when roadracing,bill
another anfob
Offline jakes parts
« Reply #16 on: July 14, 2015, 02:44:36 am »
id like to know more about this 18 volt lithium drill battery.i run a magneto and just want to run my lights indicators.is there a way to step 18 volts down to 12?
Offline jakes parts
« Reply #17 on: September 03, 2015, 08:27:13 pm »
anyone?
Offline joe p
« Reply #18 on: September 04, 2015, 05:16:59 am »
A zener diode is always operated in its reverse biased condition. A voltage regulator circuit can be designed using a zener diode to maintain a constant DC output voltage across the load in spite of variations in the input voltage or changes in the load current.
« Last Edit: September 04, 2015, 05:23:15 am by joe p »
