My "new" CB750K3 had the ignition switch bolted to the handlebar clamps. It offends my eyes in this position and I decided to move it back, assuming the bracket the switch was on would easily be bolted on in the stock location under the front of the gas tank. But lo and behold, I took off the tank and there is no bracket or hole or anything on the frame to mount the switch bracket onto. So my questions are: How does this thing normally go on? Maybe my bracket has broken off? What am I looking for? It looks like it should bolt to a small bracket with a single bolthole with a welded-on nut, or maybe the silver bracket the ignition switch is presently attached to has simply broken off the frame.
