Author Topic: Engine Rebuild - How to Determine #1 Cylinder is on Compression Stroke?  (Read 2009 times)
Offline AintNoEasyWay
Hey guys, trying to close up this K7 engine I've got. I'm having trouble figuring out whether I've set my cam to be on #1 or #4 compression stroke at TDC. Both my rocker arms on #1 and on #4 seems to be loose, as I show in this video:
Here's what my cam looks like, notch on right hand side faces up while matched to 1-4 T mark, lobes on #4 face down while lobes on #1 face up and slightly out, like a "V".
How do I determine if my cam is set up correctly? Couldn't it be on #4 compression stroke instead? Everything I've read just assumes the cam is already set up and skips to valve adjustment. Thanks.
Offline jonda500
You have #4 on compression stroke (lobes down = rocker arms not holding valves open = compression stroke)
rotate 180 degrees so #1 has its lobes down
A starter clutch thread:
So the notch on the end of the cam should actually face down when I set it up? I'm confused because all the pictures/write ups have it facing up with the lines matching the cam tower bearings/caps.
Offline jonda500
I have only done 400/500/550 cams but I don't think it matters either way(notch up or notch down) as the points fire every stroke on these? Wait for a 750 expert to chime in if you're worried :)
Offline calj737
  • I refuse...
500/550 cams notch to 3:00/9:00. But, the position of the cam lobes on 1/4 will tell you which is in compression. don't overthink what is happening with your rockers currently, especially if you've adjusted them improperly.
You can also determine which cylinder is at TDC by removing the spark plug, and using a wooden stick to measure the cylinder depth between 1/4 to confirm where the piston is.
Thanks, calj. So I'm currently 180 out? Not sure if you're agreeing with jonda. Should lobes on #1 face down instead of up like mine do in the photo? My guess would be that if the lobes face up, then the valves are pushing down toward the cylinder, is this correct?
Offline calj737
  • I refuse...
My answer is: time for you to learn how to determine that. I gave you a technique that's super easy, sure fire, and then, you can understand the cam. I'm not trying to sound prickish, but this is something to learn not be told.
It will take you 5' for a lifetime of knowledge  :)
Cool, thank you, calj.
Offline goldarrow
  • one day, i'll be an
Just for the record, calj is mentioning about 500/550 bike, but you're working on 750.  You'll be chasing your tail end if you do either 3 or 9 o'clock notch positions that he mentioned ealier.
CB550 K0
Offline jonda500
would just have to simply swap over the blue & yellow wires if you did that - or assemble the centrifugal advance with the cam turned 180 degrees
Edit: :)  stick with 12 or 6 o'clock - I didn't mean to confuse/derail the thread
« Last Edit: June 20, 2015, 09:05:31 PM by jonda500 »
Offline goldarrow
Oh oh...don't mention this....180 degrees out is just like an oil thread....you've been warned....
CB550 K0
Offline flatlander
when you are at TDC, valves can be closed or opening/closing depending on crankshaft position. compression stroke is when you're at TDC and valves are closed.
my pictures are on a 550 at TDC but the same principle applies to 750.
no.4 is on compression stroke:
no.4 is on intake stroke:
if you look over to no.1 you see the same happening there, in reverse order.
Offline Bailgang
  • Scott
  • Indiana
You are WAY over thinking this and everyone talking about a 500/550 doesn't help. In your video so long as 1-4 cyls were at TDC then it looked like you had the cam set correctly that is the notch facing up at 12 o'clock with the lines matching the cam bearing cap. It really doesn't matter whether that notch is at 12 or 6 when 1-4 are at TDC, what DOES matter is that the lines match the cam bearing cap end but just to avoid confusion then stick to having that notch at 12 o'clock.
This whole 180 degree scare has to do with cam timing not with the cams actual position and that screw up can only happen if you had the 2-3 cyls at TDC when setting the cam in place rather than 1-4 at TDC.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
