The SOHC/4 World Tour is in under way.
I had the intention to rebuild my clutch over the weekend but ended up stripping several screws . Can someone tell me the length, quantity and style of bolts to replace them with? House of Honda lists two part numbers, but I'd rather run to the hardware store instead of going through Honda.
Quote from: MCRider on June 22, 2015, 10:08:45 AMAround here the hardwares stock metric in multiples of 5mm and often case screws are like 37mm or 23mm. Too long or too short.Buddy, you gotta move! C'mon down, we have room for good-natured Motorcycle fans with plenty of short metric screws available for you Seriously though, in 3, 4, 5, & 6mm, its quite common to find 12 and 16mm lengths as they are about the only size that uses the shorter length shanks.
Quote from: 5thofhonda on June 22, 2015, 09:54:23 AMI had the intention to rebuild my clutch over the weekend but ended up stripping several screws . Can someone tell me the length, quantity and style of bolts to replace them with? House of Honda lists two part numbers, but I'd rather run to the hardware store instead of going through Honda.Did you strip the screws (not likely) or the holes (more likely). While resh screws would be nice, you mamy be looking at putting an thread insert device in the holes. Like keen-sert or helicoil.The screw length themselves can be found on a microfish parts page of any on line dealer vender. Like motogrid.com or cmsnl.comAround here the hardwares stock metric in multiples of 5mm and often case screws are like 37mm or 23mm. Too long or too short.
