Author Topic: CB500 cafe seat mounting help.  (Read 1968 times)
Offline Cleric40
« on: June 22, 2015, 12:37:30 PM »
Hi all,
I recently ordered in a new seat for my build and I am hoping some of you can help with ideas on how to mount it.
My biggest issue is with the curvature of the frame relative to the straightness/flatness of the seat.  (See pics)There is a major gap from frame to seat. Also accommodating the front mounting near the rubber gas tank mount.  I plan to do a rear hoop also but before I cut up the frame more I was hoping for some help.
The seat is somewhat flexible but I don't think it could or should bend that much.
What have some of you guys done with mounting your flat seats? Suggestions? Looking for any help or ideas you may have to help finish up this project.
Thanks in advance
Re: CB500 cafe seat mounting help.
« Reply #1 on: June 22, 2015, 01:54:07 PM »
If you want the front of that seat to sit lower to the frame rail, you will likely need to modify the subframe near the tank so the seat can drop down deeper -- looks like interference from the rear gas tank mount.
Offline Cleric40
« Reply #2 on: June 22, 2015, 02:04:03 PM »
Thanks guys. I also thought about cutting the front of the seat a bit to allow it to sit lower.
Anyone who's mounted a flat seat on a 500/550 have any advice or pics?
« Last Edit: June 22, 2015, 02:08:17 PM by Cleric40 »
« Reply #3 on: June 22, 2015, 02:12:34 PM »
Think about the following. You probably want the line of the bottom edge of the tank to flow through to the bottom edge of the seat.  You can do this by forming a metal seat that folds over the frame reals and reaches down to meet the line of the bottom edge of the tank.  In doing this the lines of the bike will flow from front to back.  The folds of the seat will follow the frame rails so they will have some curve and then the seat pad will re-even the horizontal line. You can form you seat pad to be as thick as you want it, if you want to end up with a flat (brat) style seat pad.
Offline Desert Dan
  • Some might call me an
« Reply #4 on: June 23, 2015, 02:34:46 AM »
Just idle speculation here, but if you look at the curve of the frame compared to the curve of the seat it looks like the seat is backwards. Perhaps try rotating he seat 180 and see how it lines up, the end of the seat may not flow right with the tank that way but it may fit the frame better.
Offline Cleric40
« Reply #5 on: June 23, 2015, 06:18:34 AM »
Hi desert Dan, I actually did this! Haha. It does fit better but the seat kinda gets wider at the back so it makes it look weird having the wider portion up near the front of the tank.
I'm thinking I may need to just build a seat....  Anyone interested in a brand new seat?!
