I dint look at the product specification, but your plugs or caps need to be resistor type. And I'm not 100% on whether 8s or 7s are the stock plug for your bike. But whichever it is, use the stock temp plug.
Looking at a glimpse of the bike, my instinct says the carb brass is perfectly good, dont replace it. But clean, clean, clean the ever-loving dog piddle out of it. Responsible disassembly and complete cleaning is a must on "new to you" bikes that have sat a while.
Leave the stock Reg and Rec alone, they work quite well. The battery, well, that is likely to be a different story.... Is the igntion kit listed a set of points and condensers? Make certain the points are not Daichi brand as many have problems with them. So QA is unreliable.
Grab the manual, take heaps of pictures, get some bins and baggies, 2 gallons of your favorite degreaser, a stool and a well-stocked fridge. Pull up beside the bike, music on to a polite level, and set to elbow-greasing that little love back to a safe and reliable condition.
Fuel tank needs to be removed, drained, and 100% rust free inside. If you're replacing the steering bearings, then fully service the fork oil, and especially the brake system!
