Author Topic: 550F airbox/breather  (Read 1552 times)
Online jonda500
« on: June 22, 2015, 11:34:15 PM »
Finally got rid of my makeshift snorkel - the new one came (thanks Scott!) and I attached it with two bicycle seat quick release adjuster knobs. I can confirm that this snorkel is an important part if you want to be able to use full throttle with #98 mains - seems to run even better now - I need to do a full throttle plug chop but frankly I am too scared to perform this task anywhere in the city and will have to do a trip to a nice quiet country road somewhere.
I fitted a new drain tube to the plastic air chamber drain - it comes with a little foam filter stuffed in the end that attaches to the air chamber - maybe that helped a bit too..
The airbox drain I will hook up the bite valve & tube from my hydration backpack to.
What I can't work out is how to route the tube that goes from the engine breather to the elbow at the base of the airbox. Does anyone know how this hose is originally routed? maybe down between the #3&4 carbs and the airchamber?
« Last Edit: June 22, 2015, 11:40:13 PM by jonda500 »
A starter clutch thread:
Offline Scott S
Re: 550F airbox/breather
« Reply #1 on: June 23, 2015, 03:38:11 AM »
 Your welcome, Jonda!
 Yes, the breather goes between the 3/4 carbs and down....then to the RH side of the air box and on to the elbow that attaches there. I can snap a pic if you have trouble visualizing it.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline PowerMax
« Reply #2 on: June 23, 2015, 07:16:45 PM »
Is that considered carbs 3&4 on the right side of the engine (when seated on the bike) or is that carbs 1&2?  I guess my question is - when seated on the bike - is carb #1 on the left side or the right side of the bike?
76 CB 550K
« Reply #3 on: June 23, 2015, 07:21:32 PM »
...when seated on the bike - is carb #1 on the left side of the bike?
yes
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #4 on: June 24, 2015, 01:23:50 PM »
Thanks for that info, Jonda! I thought it was just an open tube. Just ordered one from JT Marks because of this bit. Any response about where the air chamber breather is routed? Does is just go towards the right side, or back down in front of the swingarm like the carb overflows/breathers?
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline flatlander
« Reply #5 on: June 24, 2015, 01:35:07 PM »
here are 2 pictures that might help you - but i think you're on the right track now anyway.
Online jonda500
« Reply #6 on: June 24, 2015, 08:52:11 PM »
Thanks flatlander :)  -I just went out to clark rubber and picked up some 3/8" fuel/emission tube and I can see from the pic that it heads down in front of the carbs #3&4 if you have the later model breather cover.
My breather cover has the outlet on the other side, but now that I have nice new flexible tubing I am sure I'll be able to figure out a suitable route using trial and error!
Offline flatlander
« Reply #7 on: June 24, 2015, 10:17:54 PM »
... as long as you don't put any unnecessary bends and kinks in it, it should be fine.
does the partslist show the routing for your model?
Online jonda500
« Reply #8 on: June 24, 2015, 10:49:01 PM »
the parts list gave me no clues except a part number and description (TUBE 12x420) on the cylinder head cover page. I ended up from the breather running it down the middle in front of the carbs but behind the fuel line that goes to #3&4 carbs, then under the carbs like the one in the bottom picture.
So now the only smoke I will ever smell or see, if any, will come out the exhaust! :)
Offline flatlander
« Reply #9 on: June 25, 2015, 06:01:33 AM »
cool, congratulations! enjoy the smoke-free environment :)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #10 on: June 25, 2015, 08:16:36 AM »
100% make SURE there are no bends or kinks in the breather hose. Pressure can build up and start forcing oil out from all over the place.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
