Author Topic: Sprocket cover STUCK 750  (Read 2734 times)
« on: June 24, 2015, 04:15:06 PM »
75 cb 750.. Head on lower screw is buggered.
 I think my only choices here are, slot the head with a dremel..( and hope it breaks loose without splitting head)... Or welding to it.
 Welding will be tricky, our only choice where bike is,  is small mig. I think I can get a bead on one side(top), but two (sides) would be way better.
Once the head is gone we are hooped.
 May just have to holesaw around bolt boss or smash cover..any ideas..?
Offline goldarrow
  • one day, i'll be an
Re: Sprocket cover STUCK 750
« Reply #1 on: June 24, 2015, 04:25:21 PM »
Can't you just dremel cut screw head off completely?
CB550 K0
« Reply #2 on: June 24, 2015, 04:56:18 PM »
or drill the head off??
Offline BPellerine
« Reply #3 on: June 24, 2015, 05:33:22 PM »
yeah drill head off and then deal with the remaining bit of screw when cover is off ,should have something to grab onto.bill
1978 CB 750K ard and webers
another anfob
« Reply #4 on: June 24, 2015, 06:18:52 PM »
OK.. Let's. See you wiggle that out, with no clearance and 2 1/2 inches of bolt holding it.. ;D ;D >:(  ;D
  I already that of that..
 I think I should mig a nut on,  rather than a bar..get a good enough bead/ penetration with the nut.
Offline Old Scrambler
« Reply #5 on: June 24, 2015, 06:51:39 PM »
Depends on what you need to do....................in the motor....................you could remove the left case cover and give yourself some room...........but that may cost a gasket :(
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Online scottly
« Reply #6 on: June 24, 2015, 09:59:45 PM »
Yes, do a rosette weld through the hole in the nut; a larger nut may work better?
« Reply #7 on: June 24, 2015, 11:25:49 PM »
Probably one of the worst screws/bolts on the bike to remove.. Drilling head off..youre sunk.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #8 on: June 25, 2015, 04:20:12 AM »
Yep, that's definitely a bad one since the cover has to lift up instead of being able to pull straight out. I have an engine sitting to the side, I can check to see whether pulling the trans cover would help.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #9 on: June 25, 2015, 05:08:50 AM »
On the F engine, I always have to remove the left side cover to get the chain cover off, thinking about shaving the chain cover a bit, since it is getting old.
Offline greenjeans
  • 1972 CB750K2
« Reply #10 on: June 25, 2015, 05:33:18 AM »
Since one of your options was smasing the cover, I agree with a try to weld a nut on there. Does the mig you have available have gas, or are you using flux wire ?  I've found that the gas really helps when welding to old bolts/nuts etc.  It seems the last 2 or 3 bikes I've had in the shop have had broken/damages screws that the PO has left for me.  Good luck.
« Reply #11 on: June 25, 2015, 06:54:20 AM »
Mad, dont go to any trouble, it will come off one way or other, was going to pull trans cover off anyway... Pretty sure the part of the cover the screw goes thru, encloses the screw..
 I got spare covers... Just pointing out , this one can be a bugger, so dont rlound it off.
« Reply #12 on: June 25, 2015, 07:04:09 AM »
Yep, the cover definitely captures the full length of the screw. If removing the trans cover allows the sprocket cover to shift outwards just a little (if the screw head is lost, leaving just the shaft of the screw) then you might be able to cut the screw between the sprocket cover and the lower case. Curious to see how it turns out. Fortunately this is one of the few bolts I have never had to deal with as far as being difficult to remove, and I've dealt with plenty!
TAMTF...
Wilbur
Projects:
Wobbly
« Reply #13 on: June 25, 2015, 07:04:38 AM »
That cover is a pain in the ass even with all the bolts off. I feel your pain.
Offline lrutt
« Reply #14 on: June 25, 2015, 07:50:42 AM »
punch and hammer. Put the punch on the out edge of the screw and hammer in the direction to unscrew it. I can't remember a time when that has not worked for me. Very effective.
« Reply #15 on: June 25, 2015, 08:04:04 AM »
Two problems with that. Where the bike is I would have to resharpen a punch. But i think we already tried it....the screwed laughed at me. The problem is getting in there..ifyour first dimplecscrews up , there is not much room to try again..
It looks easy but a lot of methods just wont work..
« Reply #16 on: June 25, 2015, 08:18:43 AM »
Cut the cover in as many pieces as needed, find another on eBay. Buy some beers and forget .....
Offline chewbacca5000
  • I polish covers!
« Reply #17 on: June 25, 2015, 04:18:39 PM »
Frank,
I think Peewee is right. I have broke that lower trans bolt casing horsing it out and it just crumbles the case casting easily.
If you can use your dremel with a cutting tool it might work out better.  It is pretty fragile so any impact will not go so well.  My K1 is missing that dam bolt in my case and is annoying.
« Reply #18 on: June 25, 2015, 04:42:34 PM »
The big solution after I get it off..
Cut across the cover ABOVE the lower bolt, then just run one bolt.
Makes life MUCH easier.....
  • I polish covers!
« Reply #19 on: June 25, 2015, 04:47:46 PM »
I'd like to see some pics off that as I want to do the same thing.
Offline Joe75
« Reply #20 on: June 25, 2015, 05:21:59 PM »
I use a product called Krawl, soak it with drops of the oil. About two days of the Krawl treatment....Carefully slot the screw head and use the old fashion impact screwdriver..  Tap tap,That's it.
« Last Edit: June 25, 2015, 05:26:12 PM by Joe75 »
1968 triumph 650
1962 hodaka 90.  70 rat 73 combat.
81 Ducati 900 SD
Zrx
« Reply #21 on: June 25, 2015, 11:23:51 PM »
You mean KROIL?
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #22 on: June 26, 2015, 06:31:36 AM »
What about drilling right into the bolt... gets rid of the head AND might allow for a bit of outward movement to remove the cover? Probably likely to damage the cover, though.
Just spitballin'...
--Evan
1975 CB750K "Rhonda"
Offline Joe75
« Reply #23 on: June 26, 2015, 07:17:30 AM »
You mean KROIL?
Sorry about that I make up my own product! Yes Kroil.
1968 triumph 650
81 Ducati 900 SD
Zrx
