Author Topic: CB550 Master cylinder internal ports  (Read 373 times)
Offline Swazi
« on: June 25, 2015, 04:35:36 PM »
Greetings ya'all, got a 76 CB550 with a corroded brake reservoir. I can see one internal port is obviously open, going into the piston chamber, but the other port appears not to be going anywhere. From my research of drawings, I can not tell if this other port goes anywhere. Any thoughts?
Thanks in advance
Don
Re: CB550 Master cylinder internal ports
« Reply #1 on: June 25, 2015, 04:49:36 PM »
There are two holes inside the resivior. you need to rod them out with a thin strand of copper wire. The piston bore can be cleaned with a gun bore cleaning brush or something the same size. Denatured alcohol is very good solvent for the dried fluid and crap.
Offline calj737
  • I refuse...
« Reply #2 on: June 25, 2015, 06:29:06 PM »
The two holes in the bottom: supply of fluid to caliper and return from caliper. The both must be completely clear for the caliper to work.
