Author Topic: carbs wont return to idle.  (Read 835 times)
Offline themanxman
« on: June 26, 2015, 09:16:48 AM »
Hello all.
I have a Z engined bike with PD51a carbs. The newly rebuilt engine will not return to idle without some assistance, ie let the clutch out a little in gear and it will come back down under load. It does go well at higher revs.
It has a fairly quiet 4 into 1 exhaust
cheap pod filters
115 main jet (also 92, 107.5, 110, 115, and 120)
return springs are strong
cables free
pilot jets have been out and are clean
new neoprene manifold rubbers (in blue, nice!)
ignition advance weights return nicely
needles are on the middle notch
fuel levels in the float bowls are at the joint/top, measured with clear tube
and the camchain clatters.
can anyone point me towards a solution ?
Cheers Pete.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: carbs wont return to idle.
« Reply #1 on: June 26, 2015, 09:36:43 AM »
does the linkage snap back down completely without the cables attached?
This is interesting. Does it stay down after this? Idle speed dropping with clutch resistance is normal (we've all stalled our bikes before!), but it would come right back up when you bring the clutch back in.
« Last Edit: June 26, 2015, 09:39:05 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
Offline themanxman
« Reply #2 on: June 26, 2015, 09:53:49 AM »
Hello. yes it comes back and stays there, it will slowly return if left alone some of the time.
Offline themanxman
« Reply #3 on: June 26, 2015, 09:55:15 AM »
Sliders seem to be working fine without cables.
Offline dusterdude
« Reply #4 on: June 26, 2015, 10:38:39 AM »
If you fix it let me know,mine is doing the same thing,been thinking its the spark advancer hanging but im leaning away from that,ordered a new cable this am.see how that goes
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #5 on: June 26, 2015, 11:21:37 AM »
make sure you haven't developed and air leak at the intake that's leaning out the idle.  with the engine running spray WD or some other silicone spray at the intake parts seams on the head side of the carbs, one seam at a time, and watch your exhaust for smoke.  No smoke, no leak.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
« Reply #6 on: June 26, 2015, 11:24:19 AM »
This is the first (and simplest) test to do.
Offline themanxman
« Reply #7 on: June 26, 2015, 12:44:09 PM »
Will try that in the morning. Thanks.
Offline dusterdude
« Reply #8 on: June 26, 2015, 01:08:58 PM »
Good idea on the wd
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline themanxman
« Reply #9 on: June 28, 2015, 01:09:05 PM »
Hello again.
Sprayed WD 40 all over manifold area and it seemed to make no difference, did the same with Easy Start, same story, sprayed the Easy Start over the air filters and the engine stalls, flooding ? Anyway. I was checking around the clamps and giving them an extra tweek when i noticed that tightening one of them caused the revs to rise ! Culprit found. My nice blue neoprene manifold rubbers are to soft, the clamps are pinching them. So I dug out the originals which were horribly stiff and quite cracked, which is why I abandoned them without having tried them in the first place  and put them back on.......IT WORKS !
Offline Muckinfuss
« Reply #10 on: June 28, 2015, 02:18:53 PM »
Absolutely the best, non-deforming, clamp tool ever made...........http://www.clamptitetools.net/       "regular hose clamps with the worm gear almost always deform the hose/tube/pipe  etc.       This thing is better, faster, cheaper.
1974 CB550
1989 Corvette
