Author Topic: 350 Twin Oil Seal problem  (Read 2283 times)
Offline JSGAuto
« on: October 23, 2006, 05:57:16 AM »
Hi everyone,
I am having a problem with an oil seal on my 72 CB350 Twin.  It is the seal that is on the left side of the motors that goes around the clutch push rod.  After running for a bit the seal pushes out, and oil goes everywhere.  I thought the crankcase could be preasureizing, but I get 150/160psi, so that is unlikely.  I also replaced the seal, and even tried a little (very little) RTV to hold it in, with no luck.
Any ideas?
Thanks
Jim
1971 CB450 Future CR Project
1974 CB550 9K mile Beauty!
1974 CB450 "Beach Bike"
1979 CB750F Basket Case
1980 CB750F Rat bike (daily ride)
1982 CB750F 5k Miles Stocker
1982 CB900F Stealth Bike
Offline dusterdude
Re: 350 Twin Oil Seal problem
« Reply #1 on: October 23, 2006, 08:53:05 AM »
where do you get the 150/160 psi from?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline crazypj
  • I'm brill, me
« Reply #2 on: October 23, 2006, 09:31:08 AM »
Check the engine breather anyway to make sure its not trapped between crank case and swing arm.
I have a set of cases so I'll take a look and see if I can find any problem areas.
Make sure you de-burr the hole so the new seal doesnt get damaged during fitting.
PJ
Offline JSGAuto
« Reply #3 on: October 23, 2006, 02:47:22 PM »
150/160 Cylinder pressure.  I figured if the rings were bad I could be pressurizing the case by it doesn't seem likely.
Thanks for the help!  I will take a closer look at the breather.
Offline jeepurz
« Reply #4 on: October 24, 2006, 05:39:23 PM »
JSG, if ya need odds ins for the motor I think Ive got a parts engine, and Havent seen you on CU lately?
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #5 on: October 29, 2006, 10:12:47 PM »
had a twinstar 200 with a plugged breather tube. blew the shifter seal clean out of the bike! the next left turn got real tricky, as that's when I learned something was wrong. :o
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline JSGAuto
« Reply #6 on: October 30, 2006, 09:01:37 AM »
Hey Guys,
Thanks for the ideas.  I will have to take a close look at the breather.  There was a rats nest in the airbox, so it wouldn't suprise me if there was an obstruction in the breather.
Jeepurz, thanks for the offer.  I will let you know if anything is needed.  I have been too busy lately, I havent even ridden in over a month!
Jim
Offline JSGAuto
« Reply #7 on: November 02, 2006, 05:06:44 PM »
I had a few molments this evening and looked at the breather.  It was rock hard.  hmmm, I squezed some more and a bunch of little nuts and other critter stuff came shooting out!  I will be replacing the tube tomorrow, and the oil seal again.
I'll let you know how it goes.
Thanks for the ideas!
Jim
Offline Green550F
« Reply #8 on: November 02, 2006, 07:16:44 PM »
F-ing mice stuffed my exhaust full of wild plum pitts! task #1,kill mice    #2 cut down plum trees!
70 Honda CL350 Cafe
Offline JSGAuto
« Reply #9 on: November 03, 2006, 05:32:44 PM »
Problem fixed!!
Thanks!
