Author Topic: help me identify front end on '76 CB750F  (Read 1996 times)
Offline riffman12
« on: June 29, 2015, 01:32:04 PM »
Hi guys,
Bike in question is a '76 CB750F. I recently bought it and am trying to figure out exactly what I'm working with here before I order parts. The previous owner claims the front end is from a '79 CB750F (owner before him did the swap). Can someone confirm this from these quick pictures I took? I can take more this evening if anyone needs more detail.
Thanks in advance. I don't want to end up buying parts that fit a 750 if these are from a GL1000 or something.
the air fill valves at the top of the forks are throwing me off:
The brakes. Same on the other side obviously:
Master Cylinder. Correct me if I'm wrong, but this is the original 1976 part and won't work for dual disks:
Here's the huge brake splitter that from my research, I think is from a GL1000. Again feel free to correct me:
Re: help me identify front end on '76 CB750F
« Reply #1 on: June 29, 2015, 01:35:26 PM »
you have a complete front end from cb750f2/f3 1977/78
Offline riffman12
« Reply #2 on: June 29, 2015, 03:02:40 PM »
Thank you for that. I assume That's different from the '79 that the PO claimed it was?
How about the air bleeder valves up top? Should I keep those? Can I replace them with normal caps? Is there a benefit to them?
« Reply #3 on: June 29, 2015, 04:03:31 PM »
 Air fork adapters. If the forks hold air for a while they might be useful. Or I'm sure someone here would trade for stockers.
Offline Old Scrambler
« Reply #4 on: June 29, 2015, 04:15:18 PM »
Check the threads on the caps / air-caps......................The stock air-units have different threads beginning in '79.............
I tried to 'borrow' a set of air-caps from a '79 model and they would not fit my '77 fork tubes.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #5 on: June 29, 2015, 04:43:15 PM »
I think so...79 750 was dohc so I would imagine it came with a new front fork as well.  Those air caps are aftermarket add on.  I had the same set on a cb550.  With fresh fork seals and 5 psi, the forks felt just a little firmer and more confident, but the pressure would not last for more than a few days.  Pump 'em up with a small hand pump with an accurate gauge, NOT your air compressor.  With no air, those caps perform exactly as stock.
Wobbly
« Reply #6 on: June 29, 2015, 05:17:47 PM »
I am not so sure. The 79/80 Honda CB 750F fork looks a lot like the one from the F2/F3 although it's a completely different engine. I need a side shot from the master cylinder to identify if its F1 or F2/F3. It's definitely pre-79 (round, not square). The 3-way Joint Assembly sure looks a lot like Goldwing to me. Instruments are F1 (green).
Wobbly
« Reply #7 on: June 29, 2015, 05:26:43 PM »
Somebody with better eyes than mine should make the comparison.
Wobbly
« Reply #8 on: June 29, 2015, 05:28:20 PM »
Fender is definitely F2/F3. Comstars look like F2/F3 with black between spokes and rim.
« Last Edit: June 29, 2015, 05:30:22 PM by Wobbly »
« Reply #9 on: June 29, 2015, 09:48:49 PM »
I think 78 mc...looks at the brake wires coming out of it..
Offline riffman12
« Reply #10 on: June 30, 2015, 09:24:34 AM »
OK well I can take some better pictures tonight this evening. Other than a side shot of the MC, what else would help to identify?
Thanks again for your help guys
Wobbly
« Reply #11 on: June 30, 2015, 10:16:21 AM »
Pic of front brake caliber perhaps. Fork is probably F2/F3 though since fender and Comstar wheels most certainly are F2/F3. Why don't you compare against these pics.
Wobbly
« Reply #12 on: June 30, 2015, 10:20:07 AM »
Look at the lines on top of the bottom case. I believe, they match your fork as far as I can tell from your pics--which makes them F2/F3 (410 model code). The 79 doesn't seem to have them. But, again, my eyesight is not as good as it used to be. :(
