Author Topic: CB550 Charging system SHU232-12 R/R question  (Read 871 times)
Offline links56
« on: June 30, 2015, 01:44:52 PM »
I have a 77 cb550 that I made into a bobber. When I got it all the harness and wiring components were hacked up and not on the bike. I tried to wire up the original system with the separate Regulator and rectifier and the rectifier was bad. I had a SHU232-12 regulator and rectifier combo so I wired that in. My question is, Is the the SHU232-12 intended for a permanent magnet alternator? Right now I have the field hooked to my ignition switch so it puts out the max. I think it is a shunt type R/R and It would regulate the full output from the stator. Its putting out 14.5v or so at 3-4000rpm and if you slowly drop the rpm's the voltage will drop to 13v or so then it will just drop out and my meter starts bouncing around. I have not run it like this long. Any guidance would be appreciated. Thanks.
Offline calj737
  • I refuse...
Re: CB550 Charging system SHU232-12 R/R question
« Reply #1 on: June 30, 2015, 03:53:36 PM »
Others here have run that unit before with reliable results. You can search that model # and you'll see the threads and wiring schemes they used.
Offline links56
« Reply #2 on: June 30, 2015, 04:28:38 PM »
maybe im searching wrong? all i can find is this post when i search. thanks.
Offline calj737
  • I refuse...
« Reply #3 on: June 30, 2015, 04:59:28 PM »
My mistake, similar but different.
http://forums.sohc4.net/index.php?topic=60427.0
Offline links56
« Reply #4 on: June 30, 2015, 05:26:47 PM »
That was close. dang I think that model would be better for me. I'm sure this will work somehow or if i could find any documentation on the SHU232-12 I could figure it out. I can't seem to find anything, just people selling them. Thanks though.
