Support the site. Your contributions keep this site running.
Mike, thanks for posting those pics I'm sure they look even better in person I made sure to note which rod went where on the crank when I took them off, but I didn't pay attention to which end faces forward( one side is stamped with a letter ). Will it make a difference which way I put these back on?
OK, best to read the manual before asking any questions. The Honda '78 750 F/K manual covers the crank and rods pretty well. Looks like I'll be measuring everything to find out which bearings to use. If those browns are still within spec should I replace them anyway? Mike, the manual covers both K and F models(1978) and only specifies 13-15.9ft-lb torque for the rod bolts. Where are you finding the 18.8ft-lb torque for the F2 rods? Also, the manual has this to say about bearing direction when installing rods:CAUTION- Be sure the bearing caps are installed in their correct location and the bearing pawls point to the front of the engine. This would be opposite to what you suggest, or am I misunderstanding it?
Figured you had all the data sheets. The info I'm getting is from the Official Honda Shop Manual for 1978 750 K8 and F3. I got it in .pdf form from Terry long ago and it might even be available on this site. Since it covers both models I figured there would be some omissions considering the F3. When in doubt, ask someone who knows, thanks Mike I'll order up one set of Browns this week. Thanks for the tip.
Oh man...Mike,You really know your stuff. Sparty
Quote from: scondon on October 23, 2006, 08:15:35 PM Mike, the manual covers both K and F models(1978) and only specifies 13-15.9ft-lb torque for the rod bolts. Where are you finding the 18.8ft-lb torque for the F2 rods? Also, the manual has this to say about bearing direction when installing rods:OK. First, the torque figure comes from the Honda factory manual F3 supplement. I have the entire OEM Honda CB manual with every single supplement.
The rods arrived today,Mike. As usuall the pics just do not do the parts justice. They look brand spankin' new...er, I mean "better than new,...better" Ya know why I like sending you my parts for work? 'cause each time I open up the box I don't even recognize them as the parts I sent ya. All the care and work put in looks like what you would want if it was going into one of your own bikes. If there's a flaw in the part that a "noob" like myself would overlook, your quick to point it out. And I don't EVER get the feeling that you'd let something "iffy" get by just to get the work out. /quote]Second That!
I swear one of these days - I'm going for the Carillos and regret not doing it 2 months ago. 100 horsepower and 11,000 rpm shifts -
The rods arrived today,Mike. As usuall the pics just do not do the parts justice. They look brand spankin' new...er, I mean "better than new,...better" Ya know why I like sending you my parts for work? 'cause each time I open up the box I don't even recognize them as the parts I sent ya. All the care and work put in looks like what you would want if it was going into one of your own bikes. If there's a flaw in the part that a "noob" like myself would overlook, your quick to point it out. And I don't EVER get the feeling that you'd let something "iffy" get by just to get the work out. Yep, just got four balanced,polished,shotpeened rods and that all important "peace of mind", all for much less than the cost of two new rods from Honda
Why would a team packed full of great players need any who are merely good
Ok, best to read the manual before asking any questions. The Honda '78 750 F/K manual covers the crank and rods pretty well. Looks like I'll be measuring everything to find out which bearings to use. If those browns are still within spec should I replace them anyway? Mike, the manual covers both K and F models(1978) and only specifies 13-15.9ft-lb torque for the rod bolts. Where are you finding the 18.8ft-lb torque for the F2 rods? Also, the manual has this to say about bearing direction when installing rods:CAUTION- Be sure the bearing caps are installed in their correct location and the bearing pawls point to the front of the engine. This would be opposite to what you suggest, or am I misunderstanding it?
