Author Topic: CB750K2 I just did my first carburetor sync  (Read 611 times)
Offline jeremyillingworth
« on: July 07, 2015, 07:40:03 PM »
After putting it off for a while I finally got around to my carburetor sync. I got a Carb Tune and it was rather easy to set up. I put a fan on the bike but it was a very hot day, approaching 30 degrees.
I didn't want it to drag, since the bike is just idling and getting hotter but I also wanted to be patient and do it right.
I was surprised how often I needed to adjust the idle. I quickly lost the notion that it would be all perfect and all the carburetors would show the exact same reading.
I think I did a pretty good job. I found it hard to work when the idle was too low; most of my readings were taken around 22. I should have timed myself but didn't. When I was done the bike was hot. I could touch the engine but not hold my hand on it. After I shut it down I kept the fan going and after a while pushed it into the driveway and (hope this wasn't a bad idea) cooled it down with some water.
After cooling longer I fired it up and now I see what people mean by 'sewing machine sound'. A quick, three mile test run and all seemed well.
How long does it normally take you to sync up?
How long is safe to run the bike with a fan on it?
Do you just work one at a time or loosen them all at once?
Does anybody actually torque the 10mm nuts down when finished? I was going to but I found out my torque wrench doesn't go that low. I snugged them up.
jeremy
Re: CB750K2 I just did my first carburetor sync
« Reply #1 on: July 07, 2015, 07:49:17 PM »
sounds like you did fine, except there was no need to cool down with water and I hope you didn't warp anything.  The bike should be just fine idling all day with a good fan blowing.
« Reply #2 on: July 07, 2015, 08:13:53 PM »
Sync looks good.  Nice job.  Typically takes me 5-7 minutes or so once all set up with the tubes, fan aux tank, etc.  Adjust, blip, idle, repeat....
And yes, a fan is all you need.
« Reply #3 on: July 08, 2015, 05:08:02 PM »
I definitely wasn't that fast, probably at least double. I'll get an opportunity to practice every 3000 miles.
jeremy
« Reply #4 on: July 08, 2015, 06:14:02 PM »
jeremy
not usually necessary to do it that often...although it does get easier with practice
