Working on my k8 which was last registered in 1990. Before the work started, all lights - main/brake/indicators worked ok, In my haste, I connected the battery incorrectly - poles switched for a split second - enough to mess things up.
So my question is, what needs replacing on the electrical side. Front indicators are on solid, the indicator flasher no longer works - so I'm guessing the flasher unit along with the relay?
Thanks in advance.
