I am new here and have 77 CB 550K and I am having issues with the turn signals.
I took the rear turn signals, fender, and handlebars off as I was working and noticed after that the turn signals no longer worked correctly.
I put everything back the way it was and they still are not working.
After reading through a bunch of forum posts, I was able to figure out that the wire from the headlight compartment goes back to the rear signals and I could test for continuity so I know the wires are good.
When I plug the rear turn signal lights back in I get nothing, although the rear tail light does work.
If I press the turn signal, the front bulb shuts off and does not flash. It does the same regardless of which direction I turn.
I'm not sure what to try next. Anyone have some suggestions?
