For those who like pix and long reads, here is the not so short summary
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
(note that I skipped some pix which are in the first post by Don to avoid duplicates). If this isn't enough, there's expansive detail in my build thread for each topic
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
Happy voting!
Credits and Thankshttp://forums.sohc4.net/index.php/topic,126735.msg1701013.html#msg1701013EngineNOS Cam, Cam sprocket, tappets and adjuster nuts, Cam chain tenstioner assy.
JMR ported head, Serdi valve job, all new honed (not reamed) iron guides, stainless steel valves, kibblewhite springs, decked head with MLS gasket.
First oversize bored cylinders with yamiya psitons, rings and pins.
Micropolished crank
NOS connecting Rod and Main bearings, later model connecting rod bolts and nuts.
NOS Primary chains and roller/tensioner
NOS clutch plates (both sets), Hondaman clutch basket oiling mod, NOS clutch cable
NEW SKF bearings throughout the engine including those pesky needle rollers and groove widened roller bearings
Near New Shift forks, later model shift drum and C2-C5 combo
Fully rebuilt oil pump with NOS screen, Elan's super kit and near new impellers and end caps
Fully rebuilt starting motor with new sleeving NOS terminal cap, o-rings, brushes etc.
New yamiya spark advancer shaft and advancer springs, NOS points plate and points cover.
New sleeving and terminals for charging coil wires with new alternater subharness.
NOS oil pressure and neutral switches and oil filter bolt
NOS oil lines!!
All NOS oil seals throughout
Rechromed shifter lever, kick starter lever, rear brake lever, clutch and starter motor covers.
All engine covers polished to a chrome like finish, installed with new yamiya screws and vesrah gaskets.
Crankcakes, cylinders and head painted with VHT High Temp Aluminum paint
All NOS bolts, nuts and washers throughout.
New yamiya engine mounting long bolts.
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=291069;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=273124;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=273128;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=273132;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=290698;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=288936;image)
![](http://i992.photobucket.com/albums/af44/bentonracing/450RollergearsK0pcsshiftforks008_zps3786d03e.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=284842;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=288074;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=291087;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=290722;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=293562;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=291943;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=291945;image)
CarbsFully torn down and ultrasonically cleaned.
DIY Zinc plated all pieces
Polished bowls and crowns to a chrome like finish.
All NOS brass everything
All NOS gaskets
All NOS hoses
All NOS intake and airbox boots along with their clamps and screws
NOS throttle cables
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=257375;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=142367.0;attach=283637;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=270445;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=270964;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=287158;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=287203;image)
FrameAdded the "quiet memo" drain holes, treated insides with Eastwood's internal frame coating
Gordon's frame kit
Powder coated frame and everything that goes with it (rider foot pegs, chain guard, battery box and panel etc.)
DIY zinced pillion foot pegs and hardware
DIY zinced center stand C bracket and pivot with NOS spring, bolts nuts and washers
NOS spring and bolts for kickstand
All NOS nuts, bolts and washers throughout.
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=245225;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=246447;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=294334;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=262770;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=262774;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=262780;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=293009;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=293011;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=262776;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=262893;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=293029;image)
Wheels, Steering, Suspension and BrakesPolished hubs and all accompanying pieces (sprocket carrier, brake stay panel etc.) to a chrome like finish.
All NOS Spokes and Nipples, laced and trued within 1mm.
Continental tires with Metzeler tubes, fully balanced.
DIY zinced front axle and nut, rear axle spacer
Rechromed rear axle and nut, chain adjusters front hub bolts and speedo retainer plate
Front forks polished to a chrome like finish.
New hardchrome fork tubes with Progressive springs.
NOS fork seals with DIY Zinc plated retainers/circlips
NOS drain screws and crush washers
Rechromed fork tube caps with NOS seals.
NOS gaiters, collars, reflectors, bases and yamiya body kit fork ears.
All Ballz tapered steering stem bearings
DIY Zinc plated triple tree nut and rechromed top nut and washer
New yamiya chrome bolt kit for upper triple tree, NOS bolts for lower
Early K2 correct yamiya handlebars with NOS grips
Hondaman rebuilt swingarm with SAE grease zerks
DIY Zinc plated swingarm end caps
Rechromed rear suspension domes with NOS springs
NOS shock bushings and Chrome bolts, washers and acorn nuts
Blanchard ground front brake rotor, maked and painted inner
NOS brake hoses and banjos
Powder coated and fully rebuilt master with NOS rebuild kit
Ultrasonically cleaned, repainted and rebuild caliper with NOS seal, bleeder screw and cap, Stainless piston and Daido pads
Cut and trued rear brake drum
NOS brake shoes
DIY zinced brake cam, shoe retainer, brake actuator rod, brake stay rod and brake lever pivot
Rechromed brake pivot (wheel side), brake lever play adjuster bolt and nut
All NOS bolts nuts and washers throughout including NLA special bolts.
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=268583;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=268991;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=292549;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=267384;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=292692;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=291161;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=292686;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=270181;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=270278;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=268995;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=269770;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=262891;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=262368;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=292537;image)
Body/OverallCandy Gold Custom Yamiya body kit with tank trim
NOS mirrors
NOS seat
NOS toolkit and pouch
NOS tank and side cover logos and emblems
NOS gas tank cap and petcock
NOS speedometer and tachometer cables and their respective guides
NOS HM341s complete with heat shields, clamps, spigots and hardware
All NOS side cover mounting rubbers and special bolts and rubbers for the oil tank
Rechromed fenders and grab rail
Eastwood's rubberized undercoating followed by chrome paint on the underside of fenders
Fully rebuilt gauges with new faces, lenses crimp rings with painted housings resleeved wires and NOS base plates
Fully rebuilt airbox with K&N air filter painted black and DIY zinced internal hardware
Repainted inner rear fender
Polished oil tank cap to a chrome like finish
Yamiya caution stickers throughout
Yamiya steering stem lock cover
Diamond chain with sunstar sprockets (18/48) with DIY zinced chain splash guard
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=295860;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=295866;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=296568;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=296917;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=281931;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=281929;image)
ElectricalNew Head and tail lights
Yamiya body kit headlight bucket and tail light sub harness
New Dash harness from 4into1
Rechromed tail light mounting bracket
All NOS turn signals and turn signal stems, z1 repro rear turn signal mounting brackets
NOS Points plate, Ignition coils, spark wires, spark plug caps and spark plugs
K2 correct Reproduction wire harness
DIY subharness B for a functioning turn buzzer and buzzer cancel button
NOS Regulator, Rectifier, Fuse Box, Starter solenoid and bracket, Flasher relay, Horn
NOS A and B cables with New Scorpion AGM battery
NOS key switch and steering stem lock
Fully rebuilt handlebar controls with powder coated lettering detail!
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=258325;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=291661;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=293788;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=294391;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=295564;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=295758;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=295413;image)
Before/After![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234115;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-18.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234117;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-95.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234119;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-26.jpg)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-146.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234121;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-73.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234125;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=290692;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234129;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-66.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234141;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=296919;image)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234145;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-15.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234147;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-99.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234151;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-96.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234155;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-51.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234153;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-82.jpg)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-122.jpg)
![](http://forums.sohc4.net/index.php?PHPSESSID=r8gqc98ee2gf6rkqurvreuq687&action=dlattach;topic=126735.0;attach=234157;image)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-85.jpg)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/11152013755.jpg)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-78.jpg)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/10182013555.jpg)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-76.jpg)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/10182013554.jpg)
![](http://i160.photobucket.com/albums/t170/EdwardMorris/CB750/Honda-54.jpg)
