Author Topic: MessnerMoto - CB750 f2 - Some Parts are now available from build!!  (Read 88339 times)
Offline MessnerMoto
Re: MessnerMoto - CB750 f2 Caferacer build - I need set of finned covers
« Reply #275 on: December 19, 2016, 05:07:17 AM »
you are reading my mind ;) This is what I tied but if you think about it there are angles measurement involved... Ports openings are angled in 2 axes compared to top surface of the head. But maybe I can stick straight 35mm tube in to a port and then measure closer to neck axes...
Offline MessnerMoto
« Reply #276 on: December 27, 2016, 04:56:32 AM »
I managed to measure exhaust port positions relative to frame(with  good precision I hope)
One question regarding the muffler exit position before I send exhaust tubes for bending. I am still questioning position of mufflers relative to  chain and rear tire. I am afraid that vapor and heat will have bad impact on chain and tire. Any opinions ?
Offline MessnerMoto
Re: MessnerMoto - CB750 f2 Caferacer build - Exhaust pipe CNC bending
« Reply #277 on: December 27, 2016, 05:18:30 AM »
That shouldn't be an issue given that while riding, wind will take the exhaust gas straight away. Only while sitting and idling will the chain be subjected to heat radiating from the exhaust. I don't expect you're planning on sitting traffic too much  ;)
;) Exactly the issue is while idling... And I am more concerned with water vapor then heat. As we now more then half of product from gas combustion is water vapor
Offline Lostboy Steve
« Reply #278 on: December 27, 2016, 06:20:23 AM »
Ok... now 3D print a model of it. ;) this is #$%*ing awesome!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #279 on: December 27, 2016, 07:17:34 AM »
yeah, mirk has things going on here  ;D
« Reply #280 on: December 27, 2016, 07:31:49 AM »
Yeah but modern chain lubes are great. I don't think that will be an issue at all. If you use a standard RK black chain you'll probably have a bit of rust residue anyway just because that's what they do.
Seriously, push that program through a 3D printer and make 1/10th scale models for us?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline MessnerMoto
« Reply #281 on: December 27, 2016, 07:58:40 AM »
It goes directly to CNC tube bending. There is no need for mid steps ;)
« Reply #282 on: December 27, 2016, 08:03:37 AM »
Straight pipes or baffled?
Offline MessnerMoto
« Reply #283 on: December 27, 2016, 08:12:00 AM »
I designed pipes so they can be fitted with
1.375" ID
1.375"x2.88"x8.50"L
2.88"x 1.375"x 2.0"L
12" OAL. MS perforated core w/SS wool wrap.
MC-1375-12-SS
coneeng mufflers. They are really expensive. 100$ per muffler. They are straight cores.... I would like baffled version and cheaper
Offline SF
  • I burn gas very well
« Reply #284 on: December 27, 2016, 10:00:23 AM »
That's quite the process! Very cool
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Godffery
  • Godffery's Garage
« Reply #285 on: December 27, 2016, 10:37:27 AM »
I'm thinking longer would be better.
Perhaps You could have the pipes made longer, then cut them down later if desired ?
« Reply #286 on: December 27, 2016, 08:44:29 PM »
+1, The exhaust will not hurt the chain or tire but I think you will be losing some low and mid range  with them that short.
Offline MessnerMoto
« Reply #287 on: December 28, 2016, 01:52:59 AM »
Some things need to be sacrificed for the looks ;) I have an idea how to connect all for pipes to get something like 4-2-1 maybe that would help
« Reply #288 on: December 28, 2016, 03:14:30 AM »
I think longer pipes are gonna look better too. ;)
« Reply #289 on: December 28, 2016, 04:44:15 AM »
CNC bending....man I'm a mile behind on all the cool processes happening. The pipes look cool indeed and I appreciate how well they're tucked up for clearance, nice work. This from a guy that builds trial & error by eye!
However while you're "on the drawing board" have you added more length with some gentle curve on the muffler end to see how that looks? Still tightly tucked in of course!  8)  A nice 4-2-1 would surely be cool as well. Keep up the good work.
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #290 on: December 28, 2016, 07:09:21 AM »
I love following along with this build.  It makes me feel like a caveman with sticks and stones trying to craft a cart to pull behind an ox.   :)
« Reply #291 on: December 28, 2016, 10:29:42 AM »
My buddy. ( who has a bodyshop)
Refers to ... when working with minimal tools..
 As ..working with a Stick and a Carrot.......lol..
Offline MessnerMoto
« Reply #292 on: December 28, 2016, 12:03:29 PM »
I am using this "new" tools because I am lazy ;) and it is relatively cheap.... And it is cleaner... siting in front of screen ;)
 But i am pretty sure that original pipes or part of pipes have been bent on NC(numerically controlled) tube benders... Old technology..
Thanks to all who help clear muffler position doubts...
I gained some pipe length in front. At front of the frame pipe is really curved... I will still decide should I connect all 4 pipes somehow. I have an idea and it is easy to do... Of corse it will not be visible ;)
Offline Godffery
  • Godffery's Garage
« Reply #293 on: December 29, 2016, 10:21:07 AM »
 When you say "Connect all 4 pipes" is that as in brackets? or crossover pipes?
« Reply #295 on: December 29, 2016, 01:25:27 PM »
Yes... crossover.
Damn that sounds even cooler!!
Offline Godffery
  • Godffery's Garage
« Reply #296 on: December 29, 2016, 08:56:50 PM »
 That gets pretty tricky.
Offline MessnerMoto
« Reply #297 on: December 31, 2016, 06:02:27 AM »
I posted this here http://forums.sohc4.net/index.php?action=post;msg=1873223;topic=162721.0
This is VFR800/R6 stator stator/rotor conversion I've done ....
Offline Godffery
  • Godffery's Garage
« Reply #298 on: December 31, 2016, 08:10:24 AM »
  :o ...!
« Reply #299 on: December 31, 2016, 08:20:45 AM »
Very cool.  Are you converting to EFI?
