The SOHC/4 World Tour is in under way.
Quote from: MessnerMoto on July 23, 2015, 07:22:38 AMQuote from: zekd on July 23, 2015, 06:42:56 AMPlease sell me one of those clamps!Wait a little bit.. I just started posting in this forum But thxI'm interested as well. I noticed on your instagram page (https://instagram.com/p/5J5XIGN7zW) that you mentioned "Production line..." I confess, that made me sit up in my chair!
Your bottom clamp has no steering stop integrated into the part?
Quote from: knottedknickers on July 23, 2015, 11:16:32 AMQuote from: MessnerMoto on July 23, 2015, 07:22:38 AMQuote from: zekd on July 23, 2015, 06:42:56 AMPlease sell me one of those clamps!Wait a little bit.. I just started posting in this forum But thxI'm interested as well. I noticed on your instagram page (https://instagram.com/p/5J5XIGN7zW) that you mentioned "Production line..." I confess, that made me sit up in my chair! Yes I did 5 top clamps(stems, nuts) because I was thinking someone will interested also, but not this fast I need to check some things before I can give them. Also I would like to be first to use them... But when I see how much I go in to details...
Are you sure that the motor in the frame on the right is an F motor, as the crankcase is not black?
That's some impressive work. It looks like you are a bit further along in the project and catching us up. Showing the build progress in increments is better than, "hey it's all done" in one post. That's a pretty wide front rim. What size tires are you planning to use?
Quote from: CB750 Cafe Racer Fan on July 31, 2015, 07:37:47 AMThat's some impressive work. It looks like you are a bit further along in the project and catching us up. Showing the build progress in increments is better than, "hey it's all done" in one post. That's a pretty wide front rim. What size tires are you planning to use?Current stage of build is more of making all of nacecary parts and than making the build in short time . I think it would be stupide if I posted all at once. It would look like spam.
Nice hub, looks good, how much would they cost?, I think it carries a lot of extra weight though, compared to your rear, or say a flattrack quick change hub..
What is the total spoke count on that front hub?
Just found this. Beautifully concieved parts. Keep em coming Sent from my iPhone using Tapatalk
You know were all gona come knocking for those top triples and hubs right? Haha fine work sir
No pause..full steam ahead... Some of us got less time left..
Tank
Quote from: MessnerMoto on August 11, 2015, 12:16:26 PMTankThe tank is nice (I confess, I'm a fan of the shorter, rounder tank), but the tail--particularly the transition from seat to cowl--is one of the prettier ones I've seen. Shucks, the whole thing is pretty! Even your forms could find a permanent home in mine. I hope you find solutions to your engine problems...
Beautiful design.
