Author Topic: MessnerMoto - CB750 f2 - Some Parts are now available from build!!  (Read 86497 times)
Re: MessnerMoto - CB750 f2 Caferacer build - Exhaust pipe CNC bending
« Reply #301 on: December 31, 2016, 08:36:11 AM »
Nop. old rs34 go in ;)
"Old"?  ;) ;D  Those RS34s are pretty awesome.  I was planning to use them on my 750 build until I put my 550/650 build in front of it.  They are a little bit of a pain to get onto the rubber manifolds.
Offline CR750
« Reply #302 on: January 04, 2017, 08:53:19 AM »
nice stuff, bike is coming along great
W r e n c h  ·  R i d e  ·  R e p e a t
Offline MessnerMoto
« Reply #303 on: January 10, 2018, 01:48:42 AM »
Just a short note. I finished the bike
The story came out at http://www.bikeexif.com/honda-cb750-cafe
Sorry for not updating this thread. I am willing to answer all the question.
Here are couple of hi-res pictures ;)
Offline slikwilli420
  • Master of Disaster
Re: MessnerMoto - CB750 f2 Caferacer build - FINISHED
« Reply #304 on: January 10, 2018, 04:12:14 AM »
Well done Mirko!
Offline MessnerMoto
« Reply #305 on: January 10, 2018, 05:25:51 AM »
thx ;)
...and one wallpaper
« Reply #306 on: January 10, 2018, 05:53:05 AM »
Very nice. Now go make my tensioners! :)
« Reply #307 on: January 10, 2018, 10:24:31 AM »
Beautifully tasteful, Mirko.  Thanks for letting us know it is complete, and congratulations on getting it published on BE.  This is such a refined build.
As I recall, you are using a Wiseco 836 kit, vapor-blasted crankcases, lighted crank and flywheel, upgraded charging system, head ported/polished by _______, ________ cam, custom primary and cam chain tensioners, Mikuni RS34 carburetors, Custom 4-1 air filter/box.
Any other engine mods?
Are you using the Anders 32AMP charging system or something else?
Custom fender, headlight assembly, triple trees, clip-ons, fuel tank, seat/oil tank, rearset brackets, exhaust headers/exhaust megaphone tips, swingarm and rebuilt monoshock, forks (GSXR forks detabbed), front hub, adapted KTM rear wheel, front/rear chain sprockets
Are you printing the cam chain tensioners?   :D
« Last Edit: January 10, 2018, 02:41:53 PM by SOHC4 Cafe Racer Fan »
« Reply #308 on: January 10, 2018, 10:34:11 AM »
This is definitely BOTM material.  If Shortround doesn't accept the pending nomination, maybe he and Mirko should go up against one another next month (since we already have 3 bikes up for nominations for February BOTM).  Or not. If someone nominates and seconds Mirko this month for February, then so be it!
« Last Edit: January 10, 2018, 11:12:51 AM by SOHC4 Cafe Racer Fan »
Offline mscuiletti
« Reply #309 on: January 10, 2018, 10:36:00 AM »
Stunning! Well done.
Offline 01Thomas
« Reply #310 on: January 10, 2018, 12:50:50 PM »
Hi Mirko
I've been following this thread but I never could figure out how your clip-ons attach to the forks? Could you explain it to me again, slowly?
regards
Thomas
Offline kmb69
« Reply #311 on: January 10, 2018, 02:59:22 PM »
Very nice Mirko!
Offline 02z06dave
« Reply #312 on: January 10, 2018, 04:25:21 PM »
Amazing bike! I love the insane attention to detail. I'm curious about the master cylinder setup, front and rear. Mainly, where are they and how do they work
« Reply #313 on: January 10, 2018, 07:44:35 PM »
There is probably an internal wedge and setscrew inside the handlebar.
 I really like the levers.
Offline fastbroshi
  • Puppet
« Reply #314 on: January 10, 2018, 07:49:43 PM »
754, I've never heard about anything like that and I couldn't find anything with a Google search.  How does it work?  Pictures would be most helpful if you have any.
Just call me Timmaaaaay!!!
« Reply #315 on: January 10, 2018, 08:36:04 PM »
 Ibthink he explained it in the build thread, May be a different method ?
Offline fastbroshi
  • Puppet
« Reply #316 on: January 10, 2018, 09:00:35 PM »
Messner, I'm not sure if you were aware but I think most of your pics can't be seen anymore since Photobucket changed their scheme.  I think I would speak for everybody if I asked could you pretty pretty pretty please get them rehosted when you get the chance?  I would love to pore over build process.
Many Thanks, and what a wonderful bike.
Offline CBJoe
« Reply #317 on: January 11, 2018, 07:50:46 AM »
The Chrome Fix worked for me to view all the old posted photobucket pics...  http://forums.sohc4.net/index.php?topic=168102.0
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline fastbroshi
  • Puppet
« Reply #318 on: January 11, 2018, 08:16:47 AM »
CBJoe, thanks for bringing that fix to my attention.  There's a couple other forums that can use this for sure.
Offline MessnerMoto
« Reply #319 on: January 11, 2018, 09:32:07 AM »
Thank you all!
It is ported by local guy here in Belgrade.. cam is CX-7... I did also up and down cut of gear dogs... tensioners are from PA 4.6 polyamide look in high performance part of forum... one small mode was to combine two sets of clutch fibers to get 8 plates setup with correct height.
I made my own setup for alternator... but it is similar to Anders.... using same components
I will update pictures from photobucket when I find some time
Hope this image helps
Offline 01Thomas
« Reply #320 on: January 11, 2018, 12:27:21 PM »
Thank you Mirko, that picture is worth a 1000 words.
Offline ozcaferacer
« Reply #321 on: January 11, 2018, 12:51:59 PM »
Messner, I'm not sure if you were aware but I think most of your pics can't be seen anymore since Photobucket changed their scheme.  I think I would speak for everybody if I asked could you pretty pretty pretty please get them re-hosted when you get the chance?  I would love to pore over build process.
Thank you very much for bringing that fix to everyones attention CBJoe. It seems a bit clunky but that's probably due to "operator error".
I'd stumbled across this awe inspiring build and was very disappointed with the photobucket debacle not allowing us to see the pics.
Finally, this build is a marvel in planning, engineering and taste. I have learned so much from it.
A very big thanks to MessnerMoto for sharing, as that in itself is a lot of work and very selfless of him.
« Reply #322 on: February 01, 2018, 10:38:20 AM »
Hi Mirko,
This will not be a surprise: Your CB750F2 has been nominated for Bike of the Month March 2018.  PLEASE post that you "Accept" the nomination in the following nomination thread:  http://forums.sohc4.net/index.php/topic,170405.0.html
Congratulations!
Don
Offline Cb750 Racer
« Reply #323 on: February 01, 2018, 08:01:14 PM »
Sweet bike! Followed on Instagram.
Turbo Billet Block cb750
1975 Honda CB400f
1972 Suzuki GT750J
1984 Kawasaki GPZ900 Mr.Turbo Top Gun build
2002 Suzuki Bandit 1200 Turbo
1979 Honda CBX
1990 Mr.Turbo Kawasaki ZX11
And Dozens More...
Offline MessnerMoto
Re: MessnerMoto - CB750 f2 - Parts are now available - CNC oil pump rotors
« Reply #324 on: September 16, 2018, 04:12:04 AM »
Because I did a lot of engineering, CNCing, etc... for this project I have a lot of parts that I can now offer to general public.
The first part is replacement set of oil pump rotors for CB750.
When I rebuild my pump for my project I bought 3 used oil pumps from ebay in order to assemble one good. But I haven't succeeded because all rotors in 3 oil pumps were ruined.... I ended engineering and making on CNC set of oil pump rotors for myself.
Material is 4732 steel... Already at 30 RC of hardness. Superior to original sintered rotors(10RC).
And tolerance between rotor tips is going to be around 0.1mm. Better then original OEM pump.
This will get your oil pump to better then OEM new state and for less then what OEM rotors would cost if they were ever available...
Contact me using PM or info@messnermoto.com
The price is low because I want to move big volume and this will help people extend the life of there precious CB750s ;)
Price is 120EU for complete set! Shipping is 8EU worldwide.
« Last Edit: September 16, 2018, 04:14:39 AM by MessnerMoto »
