I've got three more ARD's in my garage, I must put another one on EBay...........
Hey Terry,
What does this magneto bring? Better spark? Is it better than for example DYNA?
Cheers, Rob
G'Day Rob, yeah, like Mike says, the ARD's nowadays are more about form, than function. I suggested installing a Dyna S in one earlier, for the same reason, in fact you could install the Dyna "points plate" in it's normal location, and as Mike suggests, install new Dyna mini coils in the original magneto housing, although you'd still need a battery, of course.
The Ard magneto's that I have are the Mk2 electronic versions, all off Kawasaki drag bikes, and I suspect that the owners flipped the ARD's for Dyna S with little batteries to reduce the weight, and improve the reliability. Interestingly, two of the ARD's look like they've been "retro-fitted" with points, probably again, because the electronic ARD's weren't all that reliable.
They do look sweet though, it's a bit like architecture, modern designs work much better, but nothing compares to the look of a grand old house...........
