Author Topic: ARD Magneto  (Read 133667 times)
Offline voxonda
Re: ARD Magneto
« Reply #325 on: May 12, 2008, 07:31:03 AM »
 The Dyna 2000 is the best ignition you can buy at a retail level. The ARD is more for a achieving a particular look. It does throw a better spark than a stock CB ignition. I believe those units have a fixed advance which can make cold starting very interesting (especially if you are kicking it). I said before if you wanted the look of the mag you could gut it, install the Dyna 2000 and fit the new mini Dyna coils in the mag head. Best of both worlds I guess.
[/quote]
Thanks, could not imagine that it would do better than a more modern unit, but it sure looks the "bizz". Would certainly want one to fit on my Turbo bike. Hope I can find one some day. Think it's a great idea to put a Dyna or similar in it.
Cheers.
Offline ttr400
    • ttr400 Projects and Billet parts.
Re: ARD Magneto
« Reply #326 on: May 12, 2008, 11:54:06 AM »
I don't know much about these ARD units, so I was wondering do you run without a battery? Is it actualy a magneto ignition that generates it's own power.
Just curious.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline puppytrax
Re: ARD Magneto
« Reply #327 on: May 12, 2008, 12:32:51 PM »
You could. I did, on my Triumph...but if you run lights, you'll want to replace the battery with a capacitor...
Yep. IIRC, the biggest advantage is that it gives consistent spark all through the rev range.
Yes, mine have a fixed advance. I've never had a problem starting, especially kicking. The spark is *hot*!!!
(If you want to have some fun, have a buddy/wife hold an unattached lead while touching the engine...and crank it over!!!)   ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Re: ARD Magneto
« Reply #328 on: May 12, 2008, 04:50:34 PM »
I've got three more ARD's in my garage, I must put another one on EBay...........  ;D
Hey Terry,
What does this magneto bring? Better spark? Is it better than for example DYNA?
Cheers, Rob
G'Day Rob, yeah, like Mike says, the ARD's nowadays are more about form, than function. I suggested installing a Dyna S in one earlier, for the same reason, in fact you could install the Dyna "points plate" in it's normal location, and as Mike suggests, install new Dyna mini coils in the original magneto housing, although you'd still need a battery, of course.
The Ard magneto's that I have are the Mk2 electronic versions, all off Kawasaki drag bikes, and I suspect that the owners flipped the ARD's for Dyna S with little batteries to reduce the weight, and improve the reliability. Interestingly, two of the ARD's look like they've been "retro-fitted" with points, probably again, because the electronic ARD's weren't all that reliable.
They do look sweet though, it's a bit like architecture, modern designs work much better, but nothing compares to the look of a grand old house........... ;D
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #329 on: May 12, 2008, 05:10:30 PM »
NO...........................:)
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Re: ARD Magneto
« Reply #330 on: May 12, 2008, 05:23:41 PM »
NO?  ::)
Offline puppytrax
Re: ARD Magneto
« Reply #331 on: May 12, 2008, 06:19:26 PM »
The owner of this last eBay auction (still going on) was kind enough to email me the two page instruction sheet for the Honda 750 Magneto (the FM mag). It's in PDF form; if anyone can post a 3.33MB PDF doc, let me know and I'll email it. I'm on a dial-up, so if we can post it somewhere, so much the better. Maybe we could even make it a sticky...  :P ::) :D
Re: ARD Magneto
« Reply #332 on: May 12, 2008, 07:59:20 PM »
Re the 750 ARD mags,
 I dont know when you think they were made, but they are all 25 or + yrs old to the best of my knowledge.
« Last Edit: May 12, 2008, 08:53:52 PM by 754 »
Re: ARD Magneto
« Reply #333 on: May 12, 2008, 08:37:39 PM »
Yeah, that's right Frank, I think we all knew that. The Dyna S is now around 30 years old too. Cheers, Terry. ;D
Re: ARD Magneto
« Reply #334 on: May 12, 2008, 08:58:30 PM »
I was referring to MReick post where a comparison to Dyna was made. At the time the ARD came out, mags were the only thing that could provide enough spark for a blown fuel bike.
Some folks like the idea of being able to run without a battery..
Re: ARD Magneto
« Reply #335 on: May 13, 2008, 01:06:55 AM »
I think we've had this discussion before mate? Running a magneto on a drag bike back in the day was where the ARD was in it's element, (even though you still needed a battery and an alternator on street bikes if you wanted to ride after dark) but nowadays, particularly with the advent of small gel cell batteries, a Dyna (even a 30 year old Dyna S) is a more logical approach.
As I said, all my ARD's in the garage are off old drag bikes, but I don't think there are too many modern drag bikes running them any more. Cheers, Terry. ;D
Offline puppytrax
Re: ARD Magneto
« Reply #336 on: May 13, 2008, 03:57:15 PM »
I bought two ARD mags new from Neil Keen back in the mid-70's...  ;D
They were better than anything else on the market back then...and since my Honda is a '73, I think it'll be better than anything else I could find to put on it...   ;)
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #337 on: May 13, 2008, 05:29:56 PM »
But for some of us older guys that don't necessarily like to follow the practical
approach then the COOL factor is threw the roof when it comes to an ARD on any street bike
and thats what I really like
but thats my shared opinion too all
BIG JIM
Re: ARD Magneto
« Reply #338 on: May 13, 2008, 07:39:35 PM »
Yup I agree,
 it looks pretty cool when a slammed snarling 750 pulls up with highpipes, Webers and a mag...  there is just no comparison...
Its like a new Corvette motor is a real hottie but pull up  at the drive-in, with  an open hood 32 with a nice flattie with all the goods on it and people will run from the Vette, like it has leprosy... ;D
 Some like cafe.. some like hot-rod.. MC
 mine is a de-caf hot rod bike... ;D
Re: ARD Magneto
« Reply #339 on: May 15, 2008, 12:07:42 AM »
Well I like my ARD's too, even though the magnetos were outdated tractor maggys even in the 1970's, they do look great.
But if I had to choose a system for a bike I was gonna ride every day, I'd buy at least a Dyna S, but preferably a Dyna 2000.
If it's gonna be "show" versus "go", I'll take "go", thanks..............  ;D
Re: ARD Magneto
« Reply #340 on: May 15, 2008, 04:33:51 AM »
Offline puppytrax
Re: ARD Magneto
« Reply #341 on: May 15, 2008, 02:06:38 PM »
Well, this last FM-type ARD 750 Magneto went for $711USD...   :o
It's good to see that the price is remaining constant...   ::)
Re: ARD Magneto
« Reply #342 on: May 16, 2008, 01:08:19 AM »
I reckon it's wonderful, I've got 3 ARD's sitting in a box in my garage! I must sell one so I can buy that Dyna 2000........;D
TheAngelHeart
Re: ARD Magneto
« Reply #343 on: May 26, 2008, 11:45:28 PM »
Hello "Terry in Australia",
i am Lutz from Germany,i have two magneto`s for my Kawasaki Z 1000,both running with an extra coil,but the coils are missing  :'(
Can you help me with the extra coils or can you sell me one of your magneto if they are complete ?
Kind regards
Lutz
Re: ARD Magneto
« Reply #344 on: May 27, 2008, 04:53:08 AM »
G'Day Mate, is Lutz your first name, or your last? I only ask because my machine shop teacher in Tech School was called Herman Lutz?
Anyway, Which model ARD do you need? I've got a MK2 with electronic ignition and external coil, and two Mk3 (?) models with points, which don't need an external coil? I hear that the ARD electronic ignition external coils were pretty bad anyway, so I'd rather sell you one of the MK3's with points?
I'm going away for 2 days, but when I get back I'll post a pic of all three, so you can see the difference between the electronic ignition model and the points model. I'll be happy to trade you either one for a Dyna 2000 ignition and a pair of Dyna 3 Ohm coils. Cheers, Terry. ;D
TheAngelHeart
Re: ARD Magneto
« Reply #345 on: May 27, 2008, 05:59:51 AM »
Hi Terry,
thanks for the fast response .
Lutz is my first name :)
I think i have MK 2 magnetos but will wait until you post the picture of your magnetos if you agree.
Kind regards and have a nice day
Lutz
Re: ARD Magneto
« Reply #346 on: May 29, 2008, 03:21:38 AM »
Here you go mate, the two ARD's on the left are the MK3's (?) with points, and the one on the right is the EI MK2. Cheers, Terry. ;D
TheAngelHeart
Re: ARD Magneto
« Reply #347 on: May 29, 2008, 07:44:08 AM »
Hi Terry,
just as i thought,i have MK 2 Magnetos and the parts missing are the little silver "box" and the red coil.
What`s about the price,if you like you can send a pm to : info@rose-papier.de
Thanks
Lutz
Re: ARD Magneto
« Reply #348 on: May 29, 2008, 01:54:52 PM »
Sorry mate, if I separated them, the magneto would be useless, and as you know, you can't buy the unique ARD coil or the ARD "black box".
If you want just the coil and black box to keep shipping costs down I'll keep the magneto, but the price is the same, a "straight swap" for a new Dyna 2000 ignition and a pair of Dyna 3 ohm coils. Cheers, Terry. ;D
TheAngelHeart
Re: ARD Magneto
« Reply #349 on: May 30, 2008, 12:45:35 AM »
Hi Terry,
please say it in $,including the costs for shipping :)
Thanks
Lutz
