Author Topic: Carby identification  (Read 573 times)
Offline triple
« on: July 24, 2015, 09:07:34 AM »
Hi, I have a set of 750 carbs on my 500 racer. They came with the bike
I need to check the carb settings to do a bench set up but have been unable to I.D the carbs from the numbers stamped on the carb spigot.
Can anyone give me the float settings for this I.D that the carbs show ??
I.D ; 064A . . . .
 there are also another set of letters that show as APAt
Hope you can help..
Offline SOHC Digger
  • I'm not an
Re: Carby identification
« Reply #1 on: July 24, 2015, 10:24:34 AM »
064A is not a CB750 carb number. Can you post a pic?
Here's a chart with 750 carbs and specs:  http://www.hondachopper.com/garage/carb_specs/carb_specs.html
Offline harisuluv
« Reply #2 on: July 24, 2015, 10:30:09 AM »
it is , just not a very common one.  Off a supersport model I believe.
Offline SOHC Digger
  • I'm not an
« Reply #3 on: July 24, 2015, 10:46:35 AM »
Learn something new everyday.
Offline triple
« Reply #4 on: July 24, 2015, 05:39:26 PM »
O.K. Getting closer to solving the issue
Do you know the float settings for these carbs ?
thanks
Offline harisuluv
« Reply #5 on: July 24, 2015, 05:57:04 PM »
26MM
Offline triple
« Reply #6 on: July 24, 2015, 10:50:11 PM »
Good work Harisuluv. Thanks very much for your time.
Hopefully I can get these carbs set up and running right from herein....
