Author Topic: cb550 engine temperature  (Read 1513 times)
Offline screemn2
« on: July 22, 2015, 05:10:46 PM »
alright guys just really curious on what type of engine temp these air cooled bikes are suppose to be running....not just at as a whole but exactly where you would take the temp on an engine ...i have an inferred temp gun and am really curious and what types of temps are good and what is not ....like at the exhaust pipe coming out of the head or at the spark plug at the head .... a good temp on the fins where the jug is? .....really curious ... thanks for any input
Offline screemn2
Re: cb550 engine temperature
« Reply #2 on: July 23, 2015, 07:03:37 AM »
Thanks dave...it seams i may be running a little warm...might try to back off the timing a little bit and turn idle air screw oit a half turn to the 2.5 turn mark...runs great pulls to red line...but a little warm i think...
« Reply #3 on: July 23, 2015, 07:26:15 AM »
seems, or is?  done a temp test at the head/headers?
do your plugs indicate you are running hot?
Offline screemn2
« Reply #4 on: July 23, 2015, 08:16:22 AM »
Plugs look pretty good flybox...ceramic is good and dark...getting about 500 right at the header as close to the engine as i can get ....engine right at the jug ..not the fins..bout 240...fins bout 200...have timing ar about 8 degrees advance static...and run premium gas 93 all the time...really still just tuning around the neighborhood trying to get things dailed in...
« Reply #5 on: July 23, 2015, 08:34:45 AM »
ceramic should be coffee brown.
just be sure not to let it idle too long without some sort of airflow.
Offline lrutt
« Reply #6 on: July 23, 2015, 08:35:11 AM »
what is your ambient temp? Is this after a hard highway run, just putting around the neighborhood, what? all that can greatly impact readings etc.
From what you describe by your plugs, I'd not screw with it, especially if all cylinders look the same.
If you are in a very hot climate, put an oil cooler on it. That really is the proper way to deal with a LOT of ambient heat if necessary.
Offline screemn2
« Reply #7 on: July 23, 2015, 08:55:33 AM »
Thanks guys..it is about 80 to 85 here lately...and the plugs are a little dark for sure flybox...still working on getting things buttoned up...tail light..front brake :o...so cant really get it out on the big road yet...so yes that is just cruising around the neighborhood...35 to 55 :-\...cannot wait to get it done as i love buzzing around on this thing..it a riot ...not like my ol v65 in the power sense...but just a blast to drive :)
« Last Edit: July 23, 2015, 08:57:53 AM by screemn2 »
Offline DaveBarbier
« Reply #8 on: July 23, 2015, 09:07:45 AM »
No need. Wasting your money with zero benefits. I get the 87 or 89. Whatever is lowest at the pump. All higher octane fuel does is help prevent detonation which usually will never happen in our lower compression ratio engines generally speaking. Myth that it's better fuel.
Offline screemn2
« Reply #9 on: July 23, 2015, 09:48:01 AM »
Well at least we can all agree to disagree...with enough timing these engines will detonate and with the extra octane you can run some extra timing to get a little more power in the power band area...sure you might loose a little up top with out being able to retard it a bit up top via computer...but to say octane does nothin...i dont agree
Offline lrutt
« Reply #10 on: July 23, 2015, 09:59:35 AM »
Ok....if tuned to OEM specs....then additional octane does nothing for you.
Offline screemn2
« Reply #11 on: July 23, 2015, 10:22:21 AM »
You are absolutly right rutt....the oem specs went right out the window with pods and exhaust though... :)....as far as the carbs anyway...you can always spend a litle time on timing and fuel for a little more power)
« Last Edit: July 23, 2015, 10:26:20 AM by screemn2 »
Offline DaveBarbier
« Reply #12 on: July 23, 2015, 01:04:57 PM »
Haha, I protected myself by saying "usually" and "generally speaking"!
