SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
how to remove swingarm bushings
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: how to remove swingarm bushings (Read 915 times)
cuz
Enthusiast
on:
July 23, 2015, 06:39:09 PM »
Just tearing down my frame to get it painted and would like to remove the main bushings on the swingarm. What is the procedure? I'm sure there is a tool but has anyone used a different method. The bike is a K7.
Logged
Powderman
Master
Re: how to remove swingarm bushings
Reply #1 on:
July 23, 2015, 06:41:49 PM »
I assume you are replacing them afterwards? A blind bearing puller will work and heating the housing with propane torch will definitely ease the procedure.
Logged
cuz
Enthusiast
Reply #2 on:
July 23, 2015, 07:07:45 PM »
I just looked at the diagram in my manual and realized there is a center collar in there. Should it just come out with a punch and hammer? Once it is out I'll just carefully cut and punch out the plastic bushings. I have some new brass ones to replace them with.
Logged
Powderman
Master
Reply #3 on:
July 24, 2015, 08:46:13 AM »
Once the sleeve is out you can drive them out. Again, heating the tube will help ease them out. When installing the new ones, freeze the bushings overnight and then heat the tube and they should person easier. Use a press and not a hammer.
Logged
cuz
Enthusiast
Reply #4 on:
July 24, 2015, 08:51:23 AM »
Does the sleeve just drive out as well? I gave it a few taps and it didn't budge so I don't want to hit it harder and damage it. Thanks.
Logged
flybox1
My wife thinks I'm a
Really Old Timer ...
Reply #5 on:
July 24, 2015, 09:09:38 AM »
good stuff here from a forum member.
//www.youtube.com/watch?v=Da_ZenYu4Xo
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
Skowinski
Full Member
Reply #6 on:
July 24, 2015, 09:47:50 AM »
I used the method described here, worked great:
http://forums.sohc4.net/index.php?topic=104216.0
Logged
Powderman
Master
Reply #7 on:
July 24, 2015, 10:16:56 AM »
1/2" air impact would have made the job a lot easier. I love my air tools.
Logged
72 yellow
Expert
Reply #8 on:
July 24, 2015, 02:50:49 PM »
Instead of the freezer I put my bushings in a small cooler with a couple of chunks of dry ice. No need to heat the swing arm, they just slid in.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
