Looking through scores of forum answers relating to nearly exact question as this, and the answers vary to anywhere but the direct one. If anyone knows an example to follow the lines of theme, such as paint brand, that would be much appreciated.
Project: Painting CB400F SS frame and parts.
Frame and Swing Arm both blasted, sanded , washed prepped, and given 2 coats of Rusoleum Automotive Primer (flat black looking,) topped with 2 coats of Rusoleum Engine Enamel high heat 500 deg Gloss Black (thick, no runs. 20% Orange Peel smoothed with an "in between coats pad" compared to 00 Steel Wool,) Final finish coat of the same Engine Enamel 500Degree.)
What Color (Cheap Rustoleum preferred,) to paint the triple clamps, Caliper backs? No Powder Coating future for this frame!!
The Frame and Swing Arm came out oddly very nice, from slamming the paint on, and 10 mins of smoothing and one carefully appied thin coat of the gloss black.
Thank you!
