Author Topic: 1976 CB750 Build moving on....well, apart..  (Read 600 times)
Offline Hotwheelbill
« on: July 24, 2015, 03:55:33 PM »
Here is the point I am now with the left side covers pulled for polish. I still have to clean the carbs, pull the oil pan and clean out, and work on some basic wiring. I have a 4 to 1 coming and taking the 76 collectors off was sooo much fun. Nothing like pounding on your engine with a baby sledge!! I did find after the first one, that if you use the impact with seven blows then use a large channel lock on the impact to turn it, the screws with turn. So that is off. I am a week or so away from putting things back on the motor and a basic wiring for the first start up.
Comments....advice??
I will also have some parts for sale after I move along with it. Exhaust look ....7 out of 10 with one small hole in the #3 pipe on the bottom. Baffs gone to the wind.
edit, yes I have a replacement stator cover.
« Last Edit: July 24, 2015, 03:58:05 PM by Hotwheelbill »
I love to make my bikes worthless due to high mileage!
2004 ST1300A .... the fast one. And dragging pegs on a CT.
1972…parts bike
1974…. Rusty frame but runs
1974 CB750..... Powder coated frame and parts, waiting for $$ hot rod motor.
1972 with 1975 old school drag motor
Offline greenjeans
  • 1972 CB750K2
Re: 1976 CB750 Build moving on....well, apart..
« Reply #1 on: July 24, 2015, 04:34:24 PM »
How much for the pipes ?
Looks good.  Every time get a new one  do the same things:   Clean the holy beejeebus out of the carbs and then I do it again - eliminate fuel as a potential problem.  3000 mile tune-up.  Set timing, valve tappets & cam chain.  New plugs.  It's a Honda, it will start.  I also like new coils, plug caps and wires, but you can get away with trimming up the old plug wires if you are re-using your coils.  New plugs and plug caps - those are cheap.  drop the oil pan while you have the pipes off and clean out the oil pump & screen if you already haven't
« Reply #2 on: July 24, 2015, 05:24:14 PM »
Thanks, I did not think about the oil pump screen. Good call!!
1972…parts bike
« Reply #3 on: July 24, 2015, 05:26:53 PM »
Going back with 4 to 1 , I need studs right? Or can I just use Lowes SS bolts with lock tite
1972…parts bike
