Greetings All!
It has been a while since I updated the thread so I figured I'd pick up where I left off.
As you can see, I had to buy a new oil pump assembly before I could button up the motor, which I took care of, and I was finally able to close it up.
I painted the frame (still need to do the wheels) in 2k paint and then buttoned everything up.
I then ordered an 88 link 630 chain, which I had to cut down two links.
I went with a cone engineering shorty muffler, and at that time It was time to fire up the motor for the first time.
When I fired her up it was fairly quick, and due to synced carbs, in spec valves, and a tightened chain tensioner it sounded fantastic. Naturally, it's loud with the exhaust, but I'm a fan.
Due to the pods and the open exhaust I'm aware that it's gonna need some tuning, but at the moment the only thing I'm dealing with is a small hanging idle, and some very rich looking plugs at idle. I went from stock main jets (which I believe is 110) up to 120, and left my pilots (40) stock. So I think the mains are my problem, but I won't know until spring. For now I'm just working on cosmetics and minor electrical details all winter, from the comfort of inside my home. The bike is re-wired and only needs tails, blinkers, and a horn to be complete, but I'm going to wait on those because I have not figured out my rear fender/seat situation.
I belive I'm going to go with a tuffside cafe seat with a rear cowl that I will hopefully be able to color match to the stock paint. Only then can I deal with the tail-end lighting.
As she sits now from the left:
And from the right:
Note that the seat is a fiberglass pan I whipped up, hastily foamed, and covered in hopes I'd get a quick ride in. It detracts from the overall quality (lookswise) of the bike which is why I'm going to upgrade to tuffside, but I hope to have it upholstered in the future so I can switch to a 2-up configuration.
Also, I restored the Honda emblems to near perfection, which this picture does not show.
As you can see, both aftermarket gauges are white with fluorescent orange needles, and I wanted the cockpit to match.
(I need to get some shiny new hardware for the shock mounts, and new safety stickers).
Here is how the cockpit sits today:
I shaved and painted the stock triple until I can justify buying a new anodized one, and dropped the front an inch.
I am currently waiting on an all new set of OEM type levers and perches in black, as well as white gauge faces, and superbrite BA9S 360 bulbs. I will paint the stock needle orange in Testors paint and I believe this will be a nice match with the temp and pressure gauge. Hopefully the LED bulbs are sufficient, otherwise I will do the LED Strip mod that I've seen on here.
For a fun experiment, I'm also going to use knockoff brooks leather bicycle handlebar wrap to wrap these grips and see how they look.
And finally...I'm contemplating wrapping the Mac 4-1 in black header wrap up to the muffler.
Thanks for checking back in everybody. Comments and criticism welcome.
