Author Topic: CycleX HiPo cam chain tensioner & primary chain tensioner  (Read 37613 times)
Offline edwardmorris
  • Youngish
Re: CycleX HiPo cam chain tensioner & primary chain tensioner
« Reply #150 on: February 22, 2016, 03:06:40 PM »
Interesting tidbit, may (or may not) be of interest/relevance since HD cam chains have oval plates instead of peanuts.
http://forums.sohc4.net/index.php/topic,144549.msg1646245.html#msg1646245
Oval chains are designed to be used with straight style guides only, On models like the CB750 and the KZ Kawasakis that the chain goes around a round sprockets, should use peanut style
Offline kmb69
« Reply #151 on: February 22, 2016, 03:50:41 PM »
I have to disagree with Jay on this one unless he's strictly referring to the stock components. It depends on the design of the sprockets, guides, and rollers. If all of the previously mentioned components have sufficient clearance for the chain's side plates, ie. they guide on the rollers and not the side plates, it's all good. Everybody and their dog has been using oval plate chains for racing applications forever because they are stronger.
  • Youngish
« Reply #152 on: February 22, 2016, 04:03:41 PM »
Yes, I believe it was in ref to using HD chain with the OE tensioner set up (link in post). I'm looking into the same right now, trying to decide on the best set up for the Tsubaki 94L.
Offline kmb69
« Reply #153 on: February 22, 2016, 07:14:02 PM »
This tensioner set is designed to work with any chain including the oval link chains: http://www.ebay.com/itm/231576401099
Offline MessnerMoto
« Reply #154 on: April 01, 2016, 11:53:47 AM »
I am doing so many stuff for my project that I don't have time to post.
I finished final design of cam and primary chain tensioners.
I cut on laser some stainless steel sheets.
I am waiting for plastic to be cut on cnc.
Also I made some central wheel for cam tensioner(previous posts for explanation). It is made of 4721 steel and then nitrated to 55Rc.
And I made several torsional springs for primary tensioner. I wanted to test different diameters of wire. I ended with 3mm black wire for springs. So it is a HD spring 0.1mm more in diameter then stock ;)... And of cores you have to heat threat your springs if you want them to last...
« Reply #155 on: April 01, 2016, 12:40:24 PM »
Wow! Hoping this all goes well. We're all needy  ;)
« Reply #156 on: April 01, 2016, 01:52:42 PM »
Needy? Everyone knows you're loaded Jerry. ::)
« Reply #157 on: April 01, 2016, 05:05:27 PM »
I would think that the hardened steel tensioner wheel will pound the chain rollers to death, by focusing all the pressure in a line across the roller. As I stated on the other thread, if you want to use a steel roller, it should be a proper sprocket shape, which cups the rollers and distributes the load over a much greater area.
« Reply #158 on: April 01, 2016, 05:38:20 PM »
Just because it's Friday night......  LOL
We're all needy for better parts  ;)
« Reply #159 on: April 02, 2016, 09:33:30 AM »
We sure are, only joshing you! MM seems to have a good handle on improvements.
Offline MessnerMoto
« Reply #160 on: April 30, 2016, 01:19:07 PM »
We are getting somewhere :) bolts are just for test... It will be popriveted....
Offline Bill/BentON Racing
    • BentON Racing
« Reply #161 on: April 30, 2016, 03:01:17 PM »
Oh hell yes,  c'mon, we like your determination and work! , K.
BentON Racing Website
BentON Racing Facebook
« Reply #162 on: April 30, 2016, 04:49:01 PM »
+1    ;)
Offline gschuld
« Reply #163 on: April 30, 2016, 07:00:32 PM »
I have to say it's over my head a bit, but I applaud the effort and craftsmanship so far.
I wish you the best of luck with testing...
George
Offline turboguzzi
« Reply #164 on: May 01, 2016, 03:59:58 AM »
mirko, pop rivets? hope you mean steel rivets that are properly stalked.... personall would use countersunk bolts and rivnuts on the other side
http://www.chinafastener.com/ImgProducts/2015/7/20150730045045_X_290x250.jpg
Offline MessnerMoto
« Reply #165 on: May 01, 2016, 02:24:58 PM »
Yossef , I would need to widen the holes for pop rivets to at least 7mm from 4mm to accommodate M4  rivnuts. There is no space on some parts of sliders for that. And it would complicate machining. ..
I over engineered number of pop rivets;) I think 4mm pop-rivets are strong enough. Aluminum or steel
Offline tulsah
« Reply #166 on: May 19, 2016, 06:18:11 PM »
I posted this same question in another thread, but it may be more appropriate here ... I just acquired a 915 engine conversion that was started a couple of years back, but never completed.  Among the parts, I found this ...  What is the current advice/wisdom regarding its use?  Thanks in advance.
Offline MessnerMoto
« Reply #167 on: November 04, 2017, 11:14:14 AM »
It works.
Still testing... This was one enormous project and finally I will time to share some whotos etc... Chains are a lot quieter... I think I can do better with stronger spring for primary chain...
« Last Edit: November 04, 2017, 02:04:29 PM by MessnerMoto »
Offline kmb69
« Reply #168 on: November 04, 2017, 11:59:54 AM »
Very nice work!
Offline RAZZ
« Reply #169 on: November 04, 2017, 12:08:54 PM »
Very nice work!
+ 1
Online Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #170 on: November 04, 2017, 01:07:48 PM »
Ditto!
Offline gschuld
« Reply #171 on: November 04, 2017, 02:15:40 PM »
Very impressive.  I look forward to hearing how you find them holding up after some hours on the engine and a real thrashing.  This is first rate experimentation by going on here.  I love it.....
It would be very informative if you mounted a sound recorder near the engine(perhaps below the carbs) to record chain noise.  Doing the same on a control sample(factory chain guide bike) would offer an interesting comparison.
Offline FuZZie
« Reply #172 on: November 04, 2017, 06:45:22 PM »
Thats some nice bit of kit, sounds good!
« Reply #173 on: November 04, 2017, 07:24:27 PM »
Tremendous bit of engineering MM.
Offline 01Thomas
« Reply #174 on: November 05, 2017, 01:21:33 AM »
My thoughts exactly!
