Author Topic: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine  (Read 130471 times)
Re: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine
« Reply #125 on: August 30, 2015, 04:44:07 PM »
I agree with riverfever that rotor is going to look great and perfm great.
Are you rebuilding the caliper?  Figure you are using the stock caliper.
« Reply #126 on: August 30, 2015, 04:53:11 PM »
I am using a pair of stock Tokiko monoblocks from a low-mile GSXR.  They look pretty darn clean - plenty of life left in the pads, too.  I have a spare set of pads, if I decide to replace them.
t1_zps31hghohm by Donald Leonhardt, on Flickr
t2_zps0fewwkmi by Donald Leonhardt, on Flickr
t3_zpsjubhnopv by Donald Leonhardt, on Flickr
t4_zpsxuze5f6y by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 10:36:00 AM by SOHC4 Cafe Racer Fan »
« Reply #127 on: August 30, 2015, 04:56:48 PM »
The stock frame on the 550 has a gentle curve to the upper seat/frame rails.  I'm leaning towards using a Motolanna seat (until I decide on a custom sheet metal seat), with white overstitching, since the seat has a similar soft curve.
image_zpsdfilcfz7 by Donald Leonhardt, on Flickr
image_zpslzwbyzyt by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 10:37:22 AM by SOHC4 Cafe Racer Fan »
« Reply #128 on: August 30, 2015, 04:57:06 PM »
Painted sidecovers
image_zpsre2fqmgx by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 10:47:55 AM by SOHC4 Cafe Racer Fan »
Offline P.abrera
« Reply #129 on: August 30, 2015, 05:23:12 PM »
Dig that color a lot. Im big on neutral metallic tones
« Reply #130 on: August 30, 2015, 05:40:54 PM »
Yeah, I like those colors as well, looking good Don.... ;)
« Reply #131 on: August 30, 2015, 06:43:52 PM »
Thanks, Mick and Paolo.
I also ordered an electronics tray from Devin at Cognitomoto to sort out and hide my electrical components.
IMG_6227_zpsfwt6nmb8 by Donald Leonhardt, on Flickr
IMG_6228_113d836e-93f8-466b-923d-5cf0024ee1b2_zpsrpxfqftv by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 10:48:59 AM by SOHC4 Cafe Racer Fan »
Offline riverfever
« Reply #132 on: August 30, 2015, 06:54:55 PM »
Don I'm very interested to see (if you use it) how you mount this seat. I know Devin used a similar one on his 550 build but I haven't ever seen how it was mounted. I would rather not cut up my frame. Would appreciate it if you would send me any pics during the process. Even if they're just random shots that have nothing to do with motorcycles as I know you like to do that from time to time.
Offline Bigsam302
    • 1976 CB750F (915cc) Super Sport
« Reply #133 on: August 30, 2015, 07:02:43 PM »
Don, this is coming along nicely.  I can't wait to see it finished!
Sam
1976 CB750F (915cc) Super Sport: http://forums.sohc4.net/index.php?topic=142578.0
« Reply #134 on: August 30, 2015, 07:07:18 PM »
Chris,
Whatever could you mean??
The Motolanna seat says that it includes 4 6mm mounting studs.  I ordered one to give it a try.  I am not certain this will be the ultimate seat I stick with but it will provides somewhere to plant my backside for now.
My buddy Jay is going to weld seat mount tabs onto the top frame rails for a seat to be mounted.  I will have to see how to get this one to play nice.  The underside photo of the Motolanna seat does not show the mounting studs.
« Reply #135 on: August 30, 2015, 07:07:53 PM »
Sam
Thanks, Sam.  I've been following yours, too.  ;D
« Reply #136 on: August 30, 2015, 07:48:21 PM »
If it has a composite layup of fiberglass/etc then it should probably be supported as best you can along the edges and front.  So, form a metal or wood frame to keep it from being overstressed.
if it has a metal pan, then you are good. Just not sure a fiberglass pan or base will be strong enough without being a very thick layup unless it has some carbon fiber in the layup.
Understanding my concern?
Some nice components you have chosen for your build. It is going to look great
David
« Reply #137 on: August 30, 2015, 07:52:00 PM »
David
David,
It's a fiberglass base form.  I completely see your point.  You want to displace the stress/load as much as possible, and obviously not fail to provide adequate support (so it doesn't snap).
« Last Edit: August 31, 2015, 09:38:07 AM by CB750 Cafe Racer Fan »
« Reply #138 on: August 31, 2015, 10:59:38 AM »
The 750F hub/brake arrives today via USPS from Bill Benton!  Then it's off to the blaster and powdercoater to match the black Cognitomoto hub in front, then new Sun hoops from Buchanan's and lacing/truing.
It'll be ON like . . .
dk by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 10:50:20 AM by SOHC4 Cafe Racer Fan »
« Reply #139 on: August 31, 2015, 09:52:13 PM »
Well, the wheel hub/brake arrived in the mail today from Bill.   ;D ;D  I have the cush drive rubbers and bearings ready for when the wheel goes back together (after blasting, powdercoating and re-lacing).
The bottom end of the engine is together and ready for paint.
Offline CBertels
« Reply #140 on: September 01, 2015, 06:05:31 AM »
Looking good!  8)
« Reply #141 on: September 04, 2015, 11:00:00 PM »
I got my Cognitomoto electronics tray today.  I decided to go with the deeper tray because with the Motolana seat, I will not be able to tuck the battery into the seat cowl.  Devin was supercool and changed it out before it shipped (all in the same day).
image_zpsnocmjuwq by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 10:51:07 AM by SOHC4 Cafe Racer Fan »
« Reply #142 on: September 04, 2015, 11:26:03 PM »
Took my Old Girl out today.  I hadn't been out on her for like 6-7 months.  I forgot what a beauty and (torque) beast she is.  I go on about improving the power on my 650 and 750 engines, but there is nothing like this sucka (and she pales in comparison to many new bikes out there).  I felt like I was riding a rocket.  I wacked open the throttle in first and was up into the 60s before I shifted into second with the wheel hovering.  She's a "fun machine" but scary fast.
I felt like . . .
« Last Edit: September 04, 2015, 11:27:56 PM by CB750 Cafe Racer Fan »
Offline Restoration Fan
  • My wife will never call me
« Reply #143 on: September 05, 2015, 05:30:32 AM »
Don,
It's looking good.  Your builds always have a very refined look; I'm looking forward to seeing how it works out.
I received my "deep tray" for the 500 yesterday and test fitted it.  I like it a lot and think I'm going to go ahead and purchase one for the 550 as well.
« Last Edit: September 05, 2015, 05:33:58 AM by Restoration Fan »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #144 on: September 05, 2015, 09:05:50 AM »
I owned and rode an SP1 for many years Don. One of my favorite and most missed motos ever!
I wish Honda would start building adventure bikes with that amazing V-twin engine. KTM would have something to worry about.
« Reply #145 on: September 05, 2015, 09:19:16 AM »
The old RC is still such a fun bike.  I guess Honda's closest arrow to the bulls-eye is its new Africa (parallel) Twin.
Now if Honda made another flat tracker twin (RS750) . . .
« Last Edit: September 05, 2015, 09:23:04 AM by CB750 Cafe Racer Fan »
« Reply #146 on: September 05, 2015, 09:46:13 AM »
Those RC's were the last motorcycles to "move my soul".
« Reply #147 on: September 05, 2015, 10:22:45 AM »
With the RC, it feels like there is no resistance from the pavement and you can take off at any speed.  The sound of the exhaust is like a drug urging you to stay on the throttle.  It's a good thing the factory brakes are so good.
« Reply #148 on: September 05, 2015, 02:03:42 PM »
One of the support engineers in Sierra Vista had a crotch rocket for a while.  He lived in Tucson.  The judge gave him the option of forfeiture of the bike and MC license or facing a huge fine.  He was stopped on I10 doing in excess of 100. Limit there is 75. The officer was very angry with him as he had to hive chase for several miles as he wasn't paying attention to anything behind him and it took the cop several miles to close the distance.
I believe the bike was a Suzuki.
David
Offline grcamna2
« Reply #149 on: September 05, 2015, 02:05:45 PM »
David
Did he pay the fine ?
