Author Topic: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine  (Read 127141 times)
Offline calj737
  • I refuse...
Re: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine
« Reply #75 on: August 06, 2015, 05:10:26 AM »
Cal, totally unnecessary bud, the swingarms we are using are designed to accomodate18 inch wheels, I have a 4.5x17 rim with a 180 slick on it and it fits in a stock arm, plenty of room in front of it for the 18, which is only half inch or less bigger in that area... Most classic race 500/550/750 run 18/18 combo, look at the continental road or race attack tires designed for these applications... ;)
Yeah, I'm well aware of the road racers setup preference. Not sure what Don's intentions were though. And, he's not using a stock swing arm, so as a precaution I'll measure it for him as "his" swing arm is sitting on one of my bikes  :) I will say this. I've got a 130-16 on there now, and while I don't see any clearance issue to the frame of the arm, the stay rod (for drums) will be quite problematic without modification for a 150/160 tire.
As a reference, the dimensions I got from Devin was 13" radius from the CL of axle to peak of tmounted tire, and 5-5/8" for overall width at the peak. We all know that can differ slightly based upon which tire, but it should be close enough for local government work  :D
A 180 on a stock 750 arm? Hmmm, sounds "snug".
Offline P.abrera
« Reply #76 on: August 06, 2015, 05:32:45 AM »
Related to this, at what point in tire width on the stock 550 hub/swingarm do you have to start thinking of offset sprockets?
Offline calj737
  • I refuse...
« Reply #77 on: August 06, 2015, 05:34:16 AM »
Right at 160, Paolo
Offline P.abrera
« Reply #78 on: August 06, 2015, 07:03:19 AM »
Always ready with the info, cal. Thsnks
Theres always a lot of debate on how the different offset and angles a modern fork has will affect the steering behavior of the bike, wont a switch to a smaller wheel diameter also steepen steering angles and amplify the already quicker steering gsxr front end geometry? How did you compensate for that, Don? ...keeping notes for a future project
Offline calj737
  • I refuse...
« Reply #79 on: August 06, 2015, 07:38:23 AM »
It does/will. Earlier he cited that he had custom offset triples made by Cognito to achieve his desired geometry. Scroll back up
Edit: actually his custom trees were documented in his Bionic Mongrel thread. Sorry.
« Last Edit: August 06, 2015, 08:01:28 AM by calj737 »
Offline knottedknickers
« Reply #80 on: August 06, 2015, 07:43:13 AM »
I think you're correct that a smaller wheel will decrease rake ('steering angle') and trail. Increased offset will also decrease trail (though my understanding is that most sportbike forks have less offset (~ 30 mm)  than our CBs (~ 60 mm), which will increase trail). See http://www.autoevolution.com/news/a-quick-guide-to-motorcycle-rake-trail-and-offset-part-1-83482.html and http://bikearama.com/theory/motorcycle-rake-trail-explained/.
CB750 K6 http://forums.sohc4.net/index.php?topic=141388.0
The plural of "anecdote" is not "data" (Borgmann 2002:5).
« Reply #81 on: August 06, 2015, 12:40:00 PM »
Knotted.
I'm not sure which model CB uses 60mm offset.  550's use 45mm.  750's use 2 different offsets depending on the model and year.
Cal is correct.  I specifically ordered custom offset triples from Devin/Cognitomoto to compensate for the GSXR front end, the TTR400 swingarm and 18" wheels.
And yes, I am also using custom offset triples in my Bionic Mongrel CB750K2 build (with a 2008 CBR600RR front end).
« Reply #82 on: August 06, 2015, 01:50:26 PM »
Have a look at the CycleX racer Cal, the F bike, it uses a stock swingarm with wide tires, not sure the exact size... Here's a pic of the 750 with a 180 race slick on a 4.5 inch x 17 wheel with stock swingarm, its tight, but it fits....Not the best pics but I still have the tire in the shop.. ;)
« Reply #83 on: August 06, 2015, 01:52:08 PM »
Knotted.
K0 to K6 use 60mm offset, F1 to F3 use 50mm offsett, I think K7 and K8 also use 50mm offset    ;)
Offline P.abrera
« Reply #84 on: August 06, 2015, 04:52:38 PM »
Cool. Lots to catch up on. Always an education hangin out with you guys
« Reply #85 on: August 06, 2015, 05:22:16 PM »
Knotted.
Yeah, sorry--I should have been more specific about which bike I was referring to (my 750K6). Especially since I don't really know about 550 / 650s... :-[
I snapped a few pictures of my 750K6 upper triple with my 1996 GSX-R750 lower, for what it's worth:
I'm sure you've probably seen Sam's Fork Chart, but just in case anyone else would benefit here's the link. Lots of good info there.
I'll just sit back and watch now... :-X
« Reply #86 on: August 08, 2015, 12:00:51 PM »
650 cam and rockers packed and ready to mail to Mike Rieck (to send back to Megacycle in CA) for hardwelding on rockers and new hardweld/grind cam.   ;D
I might take one last crack at blaster soak and ULTRA heat to try to extract this bugger.  If not, off to the machinist it goes for removal.
« Last Edit: July 03, 2017, 11:32:05 AM by SOHC4 Cafe Racer Fan »
Offline flatlander
« Reply #87 on: August 08, 2015, 01:00:07 PM »
what grind are you getting? one of their 550 ones?
bummer about that stud. good luck with it!
« Reply #88 on: August 08, 2015, 03:12:32 PM »
Yes, Megacycle 126-20. 500/550/650 cam.
Offline calj737
  • I refuse...
« Reply #89 on: August 08, 2015, 03:33:53 PM »
That will wake up that motor!
« Reply #90 on: August 08, 2015, 04:40:42 PM »
Cal: Yes, that's definitely the intention!
IF anyone has a 1975 or 1976 rear CB750 Super Sport Wheel Hub & Brake they don't need  and that's in good condition, please PM me.  I reached out to Bill Benton (CB parts accumulator extraordinaire) but have not heard back yet.
« Reply #91 on: August 11, 2015, 07:41:17 AM »
Stud soaking in penetrating oil.
Newest speed bump is trying to source a new output shaft seal. They are no longer made. Western Hills may have them.
91205-426-013   OIL SEAL (36X57X13)
« Reply #92 on: August 11, 2015, 10:06:13 AM »
Don, have a weldor weld a nut to the exposed stud. Spritzing a little water on the stud after welding will shrink the stud and help it back out of there. Safest bet man.
« Reply #93 on: August 11, 2015, 11:47:43 AM »
I will give it a go, Brent.
On the good news front, I found a NOS output drive seal. Rare little bugger. It has a groove in the inner diameter for oil flow so you cannot use a generic seal.
« Reply #94 on: August 11, 2015, 10:06:00 PM »
Bill Benton was able to find a 1975-76 CB750F rear wheel in his treasure trove of parts.
image_zpsbuahuzwi by Donald Leonhardt, on Flickr
image_zpsx2iofncd by Donald Leonhardt, on Flickr
Nothing a little bead blasting and powdercoating cannot fix.  I am also looking into swapping the rear disc for a EBC pro-lite lightweight rotor like the ones on the front of my CB750 (with GL1000 front end).  This will reduce a few lbs. along with the aluminum rear rim.
195327_zpsata1fljk by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 10:32:34 AM by SOHC4 Cafe Racer Fan »
Offline MessnerMoto
« Reply #95 on: August 12, 2015, 01:02:14 AM »
What rim size you are going to use for rear at the end? :)
« Reply #96 on: August 12, 2015, 07:30:43 AM »
I am not completely decided but very likely an 18" Sun 4.25" width. It will fit the Bridgestone BT016 and the Continental Cont Road Attack 2 CR.
« Last Edit: August 12, 2015, 07:36:33 AM by CB750 Cafe Racer Fan »
« Reply #97 on: August 12, 2015, 08:38:35 AM »
For those interested in shaving some weight on their CB750F bikes, EBC make a pro-lite rotor that fits all 1975-78 CB750F models - Part No. MD1064 (http://www.dynoman.net/brakes/ebc-apps.html).  I found one for $120.
« Last Edit: August 12, 2015, 08:41:53 AM by CB750 Cafe Racer Fan »
Offline MessnerMoto
« Reply #98 on: August 12, 2015, 09:06:41 AM »
I like more BT016 design. But personally I would choose sport touring tire ;)
It is hard to get something wider then 18"x4.25"... There are excel rims wider then 4.25 but they are non dimpled. I just don't like non dimpled look :)
« Reply #99 on: August 12, 2015, 09:20:52 AM »
I would agree on availability.  I really don't want anything wider.  I have Excel high-shoulder rims dimpled rims on my 9 Lives CB750 bike.
They are nice-looking and lighter wheels.
Sun also makes a slightly more affordable 4.25" wheel.  http://www.buchananspokes.com/categories/rims_sun.asp
« Last Edit: August 12, 2015, 09:22:23 AM by CB750 Cafe Racer Fan »
