Author Topic: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine  (Read 145963 times)
Re: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine
« Reply #375 on: February 01, 2016, 03:05:29 PM »
Yeah, Sam, I am still leaning that way for now.  It also depends on how well the electronics pan hides everything.
« Reply #376 on: February 01, 2016, 03:11:40 PM »
Yes, do something different Don, otherwise it will just look like the 750, F tank and same tail.... ;)
Offline MessnerMoto
« Reply #377 on: February 01, 2016, 03:32:19 PM »
Design of Ian's seat goes together with f tank. Designs match
« Reply #378 on: February 01, 2016, 03:45:39 PM »
Yes, I know, but Don already has that combination on his 750.... ;)
« Reply #379 on: February 01, 2016, 03:53:23 PM »
I like the shape of the Motolanna seat but I am not a huge fan of the vinyl.  The shape of the seat, follows the 550 frame rails closer, and as Mick pointed out, I have done that tank/seat combo previously on my other 750.
Maybe I'll re-upholster the Motolanna seat down the road.
« Reply #380 on: February 01, 2016, 04:15:51 PM »
Thought about making your own seat Don, wouldn't be that hard.... ;)
« Reply #381 on: February 01, 2016, 04:30:29 PM »
If I really wanted to, I could spend a day at Ian's and he would walk me through it.  I am not sure how pretty it would be though!
I think that for now, I'll use what I have and save a second custom metal seat for later.   ;)
Offline MessnerMoto
« Reply #382 on: February 01, 2016, 05:10:53 PM »
You can draw the design for him ;)
« Reply #383 on: February 01, 2016, 06:09:16 PM »
Actually, I have a good F model tank, I'm currently trying to work out what type of seat or tail to use with it, I may end up modifying/ reshaping a stock seat base or another seat base yet... ;)
« Reply #384 on: February 01, 2016, 08:45:24 PM »
The 750F tank is my favorite of the whole 750 series.
« Reply #385 on: February 01, 2016, 09:00:40 PM »
Yes, I like them too Don, a lot don't though...
« Reply #386 on: February 01, 2016, 09:37:17 PM »
Has anyone used these lights? They have a white side facing LED to illuminate a license plate and then amber turn signals -- and mount the license plate to the bike.
lights_zpsbykodwsb by Donald Leonhardt, on Flickr
I was thinking of using these on the back and something discrete on the front -- maybe the Motogadget handle bar-end mounted LEDs.
« Last Edit: July 03, 2017, 01:42:45 PM by SOHC4 Cafe Racer Fan »
« Reply #387 on: February 02, 2016, 10:18:04 AM »
I would consider the Motogadget if it also illuminated the plate.  The Motogadget ones are probably brighter, but I'll see how the dual purpose LEDs work out -- since the Motogadget ones are twice as expensive.
I will likely use the Blaze discs for the fronts.  http://motogadget.com/en/turn-signal-lights/m-blaze-disc/m-blaze-disc.html
mblaze_disc_blk_on_01_800_zps4typ4twv by Donald Leonhardt, on Flickr
mblaze_ice_fazer_an_rechts_05_800_c_zpswztck8zq by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 01:43:46 PM by SOHC4 Cafe Racer Fan »
Offline flatlander
« Reply #388 on: February 02, 2016, 11:39:35 AM »
those bar-end signals are super neat. i'm glad i'm not in the market for some or i'd be tempted.
Offline CBGhia
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #390 on: February 02, 2016, 02:42:27 PM »
These are very discrete Don.
Super bright too.
http://www.watsendesign.com/
« Reply #391 on: February 02, 2016, 02:51:02 PM »
Super bright too.
So many choices.  These look great if I decide to not go with a dual purpose light (to signal turns and to illuminate the plate).  Very discrete and bright (220 lumens).
Online Godffery
  • Godffery's Garage
« Reply #392 on: February 25, 2016, 09:01:46 PM »
 Any updates to report...?  ;)
« Reply #393 on: February 25, 2016, 09:51:11 PM »
Marinating.
Offline CBGhia
« Reply #395 on: February 26, 2016, 01:04:05 PM »
Did you ever decide on the carbs?  I have a really clean set of stock 650 carbs, but I have thought about getting a set of the 750 carbs so that I have a better choice of air filters.
I don't really want to do velocity stacks and Pod have their own headaches.
Steel Dragon makes some cool looking airboxes.  I might be able to copy that style and just make it myself...
« Reply #396 on: February 26, 2016, 02:03:16 PM »
I am not 100% decided on carburetors.  I will most likely use CR26s or CR29s.
I am not planning on using velocity stacks, because I don't want the trouble of having to cover them each time I park the bike -- to keep foreign matter out of the carburetors and engine -- or having to deal with rain.  I will likely use K&N filters since I do not have the stock 650 airbox, AND it will not fit in the 550 frame.  The Steel Dragon box for a 750 might be an option.
« Reply #397 on: February 26, 2016, 03:33:31 PM »
Shut the FRONT door! It rains in SoCal? Man I must have slept thru the next millenium...
Torrential downpours, but not in SoCal. We get the "Storm Watch" news headlines whenever it drizzles.
« Reply #398 on: February 27, 2016, 08:41:31 AM »
So, I am giving this project a re-think of sorts.  I picked up a dirt cheap 2012 GSX-R600 front in BLACK to upgrade the front (nothing else is gold on the bike).  Since Devin will allow me to swap my unused hub, and his triples fit the front, it is an easy swap.  It also features the newer Big Piston Fork (BPF) tech -- but the other GSXR was a quantum leap forward from our old forks -- and Brembo monoblock calipers.
12-600-2_zpsg4syttbk by Donald Leonhardt, on Flickr
12-600-4_zpsnrnf65q4 by Donald Leonhardt, on Flickr
12-600-7_zpsubdpbrgu by Donald Leonhardt, on Flickr
brembo2_zpskqqinktd by Donald Leonhardt, on Flickr
brembo6_zpslarzoc89 by Donald Leonhardt, on Flickr
brembo7_zpsknswnyex by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 01:47:48 PM by SOHC4 Cafe Racer Fan »
« Reply #399 on: February 27, 2016, 11:20:15 AM »
Marinating ideas . . .
While at Jay's shop last night, we had one of those "What do you think of this?" moments.  Since this project is leapfrogging the Bionic Mongrel 750 project, I wondered what the CMR Racing tank and Ian Halcott's seat would look like on the 550 frame.  Since I don't have the TTR400 swingarm for mock up, we used my CMR Racing swingarm in its place.  Frankly, I LIKE this idea.  Obviously the bottom edge of the tank will end up matching the seat line.
[image_zpskroyt9ev by Donald Leonhardt, on Flickr
image_zpsbghlukp2 by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 01:49:28 PM by SOHC4 Cafe Racer Fan »
