Author Topic: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine  (Read 125066 times)
Offline Bigsam302
    • 1976 CB750F (915cc) Super Sport
Re: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine
« Reply #550 on: January 23, 2017, 11:09:39 pm »
Don this is going to be an amazing bike!
Sent from my Pixel using Tapatalk
1976 CB750F (915cc) Super Sport: http://forums.sohc4.net/index.php?topic=142578.0
Offline sinister902
    • Anger Street Kustoms
« Reply #551 on: January 24, 2017, 06:13:50 am »
this is looking so damn good. what year 650 motor are you working with Don? what's your thoughts on carbs for it?
« Reply #552 on: January 24, 2017, 11:57:48 am »
Thank you, Sam.  I appreciate it especially coming from you.  I'm so happy your bike is out of the shake-down phase and you can enjoy it!
Offline Bigsam302
« Reply #553 on: January 24, 2017, 12:05:16 pm »
Thanks Don. It's so much fun! It sucks that this rain has been keeping me off of it. I don't know if I told you, but I'm deploying next week. I'll be checking in as much as possible.
« Reply #554 on: January 24, 2017, 12:05:29 pm »
Nick,
I'm using a 1980 head. The spacing is compatible with 750 carburetors on the 1979-80 head.
« Last Edit: January 24, 2017, 04:40:53 pm by CB750 Cafe Racer Fan »
« Reply #555 on: January 24, 2017, 12:07:04 pm »
Cripes!!  I didn't know.  Please stay safe.  If you want to and CAN get together for a ride this Sunday, let me know.
Offline Bigsam302
« Reply #556 on: January 24, 2017, 12:11:36 pm »
I definitely will!
Offline sinister902
« Reply #557 on: January 25, 2017, 09:11:59 am »
Nick,
I'm using the same for my extremely similar engine build for my 550 project that's been on the backburner almost 6yrs now.
but I'm going EFI with cbr600rr throttle bodies and microsquirt. the later 81-82 heads work REALLY nicely with mid 80's Mikunis, which are usually pretty cheap to get and rebuild. I did a set of zx600e carbs on an 81 cb650 with excellent results.
I'd say cb750 carbs would be the easiest bet....but if you could find some later 80's model mikuni CV's it would probably be even better if your goal is a lot of streetability.
« Reply #558 on: January 25, 2017, 11:14:06 am »
Nick,
Nick,
I would love to see some pics of your continuing 650/550 build, especially the EFI conversion.  I am presently inclined to source a set of CR26s racked for a 750/650, unless I find something else compelling.
Offline sinister902
« Reply #559 on: January 26, 2017, 05:17:58 am »
Nick,
I'll get a thread going when things start happening.....right now all I've done is break the motor down and send pieces of it all over the country for things I am not capable of. (Cases just came back yesterday from NILS, trans is at Fast By Gast for Undercutting, Head is with Mike Rieck)
Offline Restoration Fan
  • My wife will never call me
« Reply #560 on: January 26, 2017, 05:47:08 am »
With an undercut transmission, are you planning to drag race it?
Offline sinister902
« Reply #561 on: January 26, 2017, 07:21:31 am »
not as a specific purpose, but for the price it's worth doing while in there.....it'll NEVER be able to pop out of gear, and I'll know the trans is 100%. I may do some test and tune nights or a vintage day at NYST or something.
« Last Edit: January 26, 2017, 08:08:55 am by sinister902 »
« Reply #562 on: January 26, 2017, 09:38:43 am »
Pardon my ignorance because my knowledge on this is very limited but undercut transmissions just means it won't pop out of gears while gearing up.  It doesn't affect gearing down, correct?
« Reply #563 on: January 26, 2017, 10:09:19 am »
A back-cut/under-cut transmission should not affect downshifting, but provides a more positive hook up into gear as you accelerate through the gears. Cycle X does the service for about $290 (http://www.cyclexchange.net/Machine%20Work%20&%20Services.htm).  I'm not sure how much Fast by Gast charges (http://www.fastbygast.com/Catagories/Products/Transmissions.htm).
If you are racing the bike, I think it's a good idea especially if you are adding power/torque to the motor.  The last thing you'd want if you are trying to overtake someone is have the transmission pop out of gear.  It becomes less critical with street riding, but doesn't hurt (except your wallet).
Offline sinister902
« Reply #564 on: January 26, 2017, 11:31:05 am »
Fast by Gast is a 20 min drive from me, was a no-brainer going there for it. The gist of undercutting is that even if you don't shift 100% into the next gear, the angle of the undercut pulls the gears into 100% engagement EVERY time and prevents it from sliding out. Not necessary, but a nice feature to have....and in the grand scheme of things it's a small expense in relation to the overall cost of the build - in my case at least.
« Reply #565 on: January 26, 2017, 11:36:20 am »
So many builders don't have time or available funds to work on non-customer bikes, and their personal bikes usually sit on the back burner for a while.  It's nice that you are having an opportunity to work on this bike.  I think the development work (on EFI and charging) if successful, could be commercially beneficial, too.
Offline calj737
  • I refuse...
« Reply #566 on: January 26, 2017, 12:28:57 pm »
Nick - are you cutting both up and down? I'd only do the "up" side for Street.
Offline sinister902
« Reply #567 on: January 26, 2017, 12:35:23 pm »
you got it cal.....up only. and no cutting on 1st gear.
« Reply #568 on: February 01, 2017, 01:16:09 pm »
Well I guess the proverbial cat is out of the bag. A few of us on the forum are presently awaiting the first run of a new CB550 rear hub designed to use a modern Brembo rotor and caliper.  When I asked Devin when he might make one for a CB550, he said he was (apparently long) in the process of prototyping one for Cal.  These are very similar to the ones Devin already makes for the XS650 and CX500.
I'm hoping to have mine soon as the initial run are receiving some machining work.
Offline calj737
  • I refuse...
« Reply #569 on: February 01, 2017, 01:21:10 pm »
Awaiting the throng of sycophants to hop onboard the cool train!  ;D ;D
« Reply #570 on: February 01, 2017, 01:30:37 pm »
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #571 on: February 01, 2017, 01:38:02 pm »
Kids with their instabook and facepage these days.....
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline GV1390
  • Express Gratitude.
« Reply #572 on: February 01, 2017, 01:44:37 pm »
93' GSX-R1100, 78' CB550, 71' CL350, 71’ CB500 & 02' ZRX1200R.
Offline GV1390
« Last Edit: February 01, 2017, 01:48:41 pm by GV1390 »
« Reply #574 on: February 01, 2017, 01:45:24 pm »
 ;D ;D ;D No monetized, hipster Instagram account for me like the JW. I can't fit into that Leopard "blouse".  That said, I have no issues with Devin making an honest buck - the guy works hard and smart.
