Author Topic: Bonjour à tous from Grenoble France  (Read 737 times)
Offline Mushu
« on: August 01, 2015, 07:20:41 AM »
I leave near Grenoble in France.
I bought a CB 750 K1 Candy Gold in November 2002 and I refurbished it within 6 months.
Since restoration, I have been using it mainly in the mountains around Grenoble.
I used it for 30000 km after restoration and I don't know the initial mileage.
I recently got oil pressure problem with red light up to 3000 rpm when engine is at high temperature.
I changed four o rings as recommended by Hondaman but the duck is still alive as we say in French.
I plan to refurbish completely the engine during winter period and I am starting to prepare this project.
I try to keep my CB close to original but it is not to put it in a museum.
I suppose that I will have to change rods bearings and probably main bearings.
I will change pistons after a rebore to 0.25. When opening engine in 2002, I saw that cylinders were just at the limit before a rebore.
As you can see, my English is not so good but may improve during the project  :)
I forgot to tell you that Mushu is the name of my cat.
I will need some help during this project and I may, with my little experience, provide help on some problems that I already faced.
My bike after restoration in 2003:
https://flic.kr/p/4vDPCC
« Last Edit: August 01, 2015, 07:26:44 AM by Mushu »
CB750 K1 owner.
Re: Bonjour à tous from Grenoble France
« Reply #1 on: August 01, 2015, 09:38:46 AM »
Mushu welcome... if the oil pressure light is the only thing wrong with your engine, you might check a couple things before tearing it apart.  I would install an oil pressure gauge to confirm what the pressure actually is.  The factory sender has been known to malfunction occasionally.  Also, I am curious what viscosity oil you have been using?  Oil  pump and pressure senders fail much more often than main/rod bearings on these, especially if it has been well used and cared for.
Offline vfourfreak
  • Do you think that's wise
« Reply #2 on: August 01, 2015, 09:55:21 AM »
Bonjour et bienvenue Mushu !
Si vous avez besoin d'aide ou d'une traduction, appelez moi.
Kev
Offline Mushu
« Reply #3 on: August 02, 2015, 03:15:57 AM »
Many thanks for your welcome.
To seanbarney41: I use SAE 15-40 mineral oil. In the past year Oil red light was lighting only at idle with a warm engine. When the engine is cold, light is off. It starts after 10 to 15 kms. It seems that Oil pressure sensor react correctly, that's why a did not install an oil pressure gauge. Anyway, I was thinking to install one after refurbishing engine.
From your advise, I will anticipate and buy one. I will let you know the result of it during last quarter of 2015.
To  vfourfreak : Many thanks for your proposal. I saw already when reading some posts that I get difficulties with some words/sentences coming from usual language. I will let you know when I get trouble.
CB750 K1 owner.
« Reply #4 on: August 02, 2015, 03:57:22 AM »
15w-40 is certainly good, but 20w-50 would be better if you still want to ride a bit before any repairs, and after too.
From your description, it is entirely possible that your rod/main bearings are the culprit, but the oil pressure sender has been reported to gradually weaken in ways that mimic the symptoms of worn rod/main bearings.  Obviously, it is much easier to replace the oil pressure sender than to split the case.
Now I am curious how many miles your bike has done?
« Reply #5 on: August 02, 2015, 04:13:27 AM »
Welcome!
Offline dusterdude
« Reply #6 on: August 02, 2015, 04:28:57 AM »
Welcome,grenoble,the home of andre the giant,rip
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #7 on: August 02, 2015, 06:25:37 AM »
Welcome from Texas.
« Reply #8 on: August 03, 2015, 04:06:11 AM »
Your command of English is quite good, no worries  :)
I am a foreigner myself, moved from Prague to Virginia 18 years ago.
Offline Mushu
« Reply #9 on: August 28, 2015, 05:18:07 AM »
To Seanbarney41:
I got an Oil pressure gauge from Joker an installed it today.
With cold engine a get 70 PSI at 1200 RPM and 80 PSI at 5000 RPM. Oil light is off
After 20 mn on the road, I get 20 PSI at 1200 RPM and 60 PSI at 4000 RPM. Oil light is on at 1200 RPM and start to disappear at 2500 RPM.
After 30 mn, I get 10 PSI at 1200 RPM and 50 PSI at 4000 RPM Oil light is on from 1200 RPM to 3500 RPM.
From what I understand, Oil pressure sensor is dead and needs to be replaced.
I will search for SAE 20/50 with is more difficult to find than 10 years ago to use it during summer as I did in the past years and replace it with 10/40 during winter.
Many thanks for your advice.
Philippe M
CB750 K1 owner.
« Reply #10 on: August 28, 2015, 05:35:14 AM »
Yeah, safe to say the sensor is dead.
« Reply #11 on: August 28, 2015, 08:22:21 AM »
That's good news Philippe....gotta love these old bikes...and thanks for posting accurate information on the solution of your problem.
