Author Topic: Performance Cam for CB650?  (Read 1812 times)
« on: August 03, 2015, 08:27:01 PM »
Do any of the aftermarket cam manufacturers make higher performance cams for the 1979-1982 CB650???
Re: Performance Cam for CB650?
« Reply #1 on: August 03, 2015, 10:29:24 PM »
It seems megacycle no longer make a cb650 cam, I imagine one of their 500/550 cams would probably work seeings though they are interchangeable...
http://www.megacyclecams.com/catalog/Page32.pdf
« Reply #2 on: August 04, 2015, 05:13:26 AM »
I have a Web 58a in one street job my wife rides. It's a mild improvement, probably like a 650 cam?? Not sure about the 58b, it shows a little more duration and the same lift.
I think with your choice of pistons & compression the Megacycle 12620 will make you smile. That's the one I race with and in the smaller displacement and 29mm carbs it has a weak spot around 6K at WOT. In a larger engine with similar carbs it should work great. Don't even consider the MegaX6.
Offline calj737
  • I refuse...
« Reply #3 on: August 04, 2015, 05:14:56 AM »
Ping Mr Rieck for your MegaCycle cam and rockers. I bet the grind on my 500 would be pretty yummy in that motor
« Reply #4 on: August 04, 2015, 09:34:38 AM »
Thanks Brent and Cal.  I just sent MR an email asking for some of his sage advice.
« Reply #5 on: August 04, 2015, 10:08:36 AM »
Thanks, Mick.
Offline cb650
« Reply #6 on: August 04, 2015, 12:37:25 PM »
Some one did make a hot 550 cam that had 1mm more lift than the 650.  But at the price I wasnt that curious.
« Reply #7 on: August 04, 2015, 03:03:31 PM »
I just spoke with Mike.  He echoed Brent and Cal's advice.  Megacycle 126-20 cam and hardweld rockers.  I'm sending them to him early next week.  THANKS, MIKE!!
