Author Topic: ARFF, SPARE CARB PARTS :( What the hell are these, where they come from?  (Read 748 times)
Offline fingersofskill
1974 CB750
Soooo... I completely disassembled my carbs to give them a full cleaning.  :D
I also broke the bank apart to really clean good.
Upon putting it back together, found these 2 "spacers" that I do not know where they came from.  :-\
I searched and scoured over several carb diagrams and could not find these listed anywheres... if they are, it wasnt obvious to me.  :o
What the hell are these and where the hell do they belong?
I am ALL READY to put the carbs back onto the bike, cept for these pesky thingys...
THANKS!
« Last Edit: August 04, 2015, 04:41:50 PM by fingersofskill »
Dave
Hair blowin in the NH air, but missin the sweet VA breeze :)
My 1974 CB750
http://forums.sohc4.net/index.php?topic=101680.msg1136050#msg1136050
my only thought is that these go between the 2 banks of carbs, on either side of the spring plate?
Dave
My 1974 CB750
Offline harisuluv
They are spacers on the linkage.  There are four bolts and then 1 countersunk screw.  These are to prevent over tightening of the linkage bolts which will break it.
Harisuluv, Thanks!
Linkage...
The only linkage I know of is the choke, but there are no bolts there.
bolts and countersunk screw... sounds like the frame that all the carbs attach to?
Can you be more specific as to what linkage you speak of?
Dave
My 1974 CB750
Did you also disassemble the rack (with the lifting fingers)?
Yes, I did disassemble the rack...that is when these spacers appeared from nowhere :-(
Dave
My 1974 CB750
I am sadly trapped in a motel room 3 States away from home right now, or I could maybe take a picture of one of the many racks I have at home and send it? Then you could see an assembled set, like Harrisluv is describing. It's mighty hard to describe, otherwise. :(
Offline Redline it
  • thread killer
the belong in the new spare parts drawer
Offline harisuluv
i don't have a stock photo of that part but yes the back plate.  at the pivot point there are only 3 bolts and 1 screwk that's it.  look at the lifters.  that part is the part that is clamped.
Offline harisuluv
they go in the clamp area to prevent overtightening.
also:  if the whole backplate and lifter arms aren't still one piece and were seperated into different parts, then it's broken and you need to fix that too.
Re: ARFF, SPARE CARB PARTS :( What the hell are these, where they come from?
« Reply #10 on: August 07, 2015, 07:23:51 PM »
Ahhh, They go there...
YAY, mystery solved... MUCH THANKS TO YOU harisuluv!
and, WhoHooo, I hadnt over tightened and they slipped back in perfectly  ;D
**Hopefully I will be riding again on Sunday
Dave
My 1974 CB750
