Author Topic: CB550F Clutch set confused on what to bu.  (Read 545 times)
Offline trn714
« on: August 06, 2015, 09:49:41 AM »
Hi guys, I'm looking to replace my clutch from my 77 CB550F found this set but confused on the discription. it says
CB550F Super Sport - 1975-1977 - 7 clutch discs needed (6 are the same and 1 is different) so do I have to get another different plate? or everything is there already?   :-\
http://4into1.com/ebc-clutch-plate-set-ck1146-honda-cb550-cx500-gl500-gl650/
Offline lajos
Re: CB550F Clutch set confused on what to bu.
« Reply #1 on: August 06, 2015, 12:31:17 PM »
I just put my clutch together using that same part for a 76 CB550K. The kit comes with 7 plates, 6+1 (the top plate has different teeth). So all plates you need is in that kit. (Of course I had the luxury of having the engine in pieces and counted the plates before I ordered. If in doubt you can always order CK1147 that has an extra disc.)
« Last Edit: August 06, 2015, 12:50:17 PM by lajos »
'73 CB500 frame with '76 CB550 engine build in progress http://forums.sohc4.net/index.php/topic,148166.0.html
'09 Ducati M696
Offline lajos
« Reply #2 on: August 06, 2015, 12:38:17 PM »
Here's a pic. You can see that the top plate has fatter teeth.
Edit: Don't forget to soak the plates in motor oil before you install them.
« Last Edit: August 06, 2015, 12:50:35 PM by lajos »
'09 Ducati M696
Offline trn714
« Reply #3 on: August 06, 2015, 02:14:46 PM »
thank you so much guys!
