Author Topic: RE: Poor Man's ceramic coating  (Read 1468 times)
Offline chewbacca5000
  • I polish covers!
« on: August 06, 2015, 11:00:50 AM »
So yesterday while working on a K5 partial restore I had to figure out what to do with my poor exhaust colars that had rust on them.  After evaluating my options I decided to wire brush them, then I treated them with Rustoleum rust converter $2.50 Walmart, and follow up with Dupont silver ceramic caliper paint, and the results were amazing!
After baking in my oven at 385F for nearly an hour them came out with a very nice silver finish.  Not polished, but very attractive none the less.
What's more I repeated the process for the inside's of my 341 inside pipes and am very pleased.  Had no idea they would look this good.
A couple pics.
Offline Powderman
Re: RE: Poor Man's ceramic coating
« Reply #1 on: August 06, 2015, 11:13:32 AM »
Take a pic of them because they won't stay nice for long. You might get lucky because it was a "paint" and not a true ceramic. Nothing can be put on the part after blasting and ceramic coating without expecting failure of the adhesion of the product.
  • I polish covers!
« Reply #2 on: August 06, 2015, 11:22:33 AM »
True ceramic is green and requires lots buffing and polishing after.  No one is going to see the inside and baking the stuff should help it stay put.  Time will tell.
Offline lrutt
« Reply #3 on: August 06, 2015, 11:24:50 AM »
That caliper paint is not rated for the temps those exhaust collars will see. JetHot and the like is about the only thing that will take it. I've even had some re-chromed but it just doesn't last.
Sorry, don't mean to be negative, just that after 50 years of messing with bikes, I've tried it all and most all of it don't work.
Too bad they aren't aluminum collars, that would be the ticket.
  • I polish covers!
« Reply #4 on: August 06, 2015, 11:30:03 AM »
I along with many other members have used the dupont silver ceramic caliper paint on head and jugs with good results.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #5 on: August 06, 2015, 11:32:13 AM »
There's also engine block paint, meant for super high temps.
http://www.vhtpaint.com/products/engineenamel/
Available in every colour of the rainbow!
--Evan
1975 CB750K "Rhonda"
  • I polish covers!
« Reply #6 on: August 06, 2015, 11:34:35 AM »
Everyone says a good bake is key to durability and getting good results.  I baked the collars to avoid the stink you always seems to get when you first start it up.
« Reply #7 on: August 06, 2015, 01:32:09 PM »
true!  :o ;D
Offline Davez134
« Reply #8 on: August 06, 2015, 01:39:48 PM »
Offline Powderman
« Reply #9 on: August 06, 2015, 03:56:10 PM »
Where did you hear it is green? It can made in many colors.
Offline Powderman
« Reply #10 on: August 06, 2015, 03:58:03 PM »
VHT caliper paint is good to 900*f, your collars never see those temps. They don't work because of poor prep.
Offline Powderman
« Reply #11 on: August 06, 2015, 03:59:49 PM »
Your "super high temps" engine paint is only good for 550*, 350* less than the caliper paint.
  • I polish covers!
« Reply #12 on: August 06, 2015, 05:32:53 PM »
Have you seen pictures of the aluminum is is sprayed green, and only gets shiny after going in the tumbler.
Offline Powderman
« Reply #13 on: August 06, 2015, 06:43:53 PM »
Pictures of the aluminum what?
the particular ceramic you used was green. You said "True ceramic is green". I assumed the "T" was capitalized because it was the beginning of a sentence, not a brand name. I shoot ceramic in about 5 different colors and none are green, even the Chromex or Cerakote that needs media blasting or tumbling to polish it to a chrome like finish. If those pipes were used and not blasted with a 360* nozzle inside the pipes nothing you put in there will stay for more than a few miles before it is blown off.
« Last Edit: August 06, 2015, 06:49:30 PM by Powderman »
  • I polish covers!
« Reply #14 on: August 06, 2015, 07:07:00 PM »
Sure would like to see some pictures of your ceramic coat if you have them.  How much you charge to do a set of 4 itno 4 anyway?
Offline Redline it
  • thread killer
« Reply #15 on: August 06, 2015, 11:51:49 PM »
awesome!! If you find that for a dollar more at a hardware store other than walmart I'll send you the dollar. Walmart sucks quite a bit and is taking down a lot with it.
Offline Chachi
« Reply #16 on: August 07, 2015, 12:55:34 PM »
I've tried high temp rattle can spray on two different sets of headers with same results - both poor after a few weeks of riding. Rustoleum High Heat Ultra and VHT Flame Proof Header Primer and Paint. I'm going to get mine ceramic coated this winter and be done.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Powderman
« Reply #17 on: August 07, 2015, 01:17:04 PM »
4 into 4, probably $250-$300 for just the pipes/mufflers, heat shields extra.
Offline Chachi
« Reply #18 on: August 07, 2015, 01:28:41 PM »
My local ceramic in south eastern Virginia is 200-250 for just the headers; I have slip on muffler.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
