Author Topic: Need help replacing points assembly grommet - 1975 400F  (Read 371 times)
Offline William Cochran
« on: August 06, 2015, 11:41:14 AM »
I cannot find a separate part number for the rubber grommet (see attachment) that is used to seal the points assembly area.  Anyone know of a specific sized grommet that will work as a replacement and where I can get one?  Thanks in advance!
« Last Edit: August 06, 2015, 11:42:59 AM by William Cochran »
Re: Need help replacing points assembly grommet - 1975 400F
« Reply #1 on: August 06, 2015, 12:12:25 PM »
The part is not available individually, only as part of the points plate assembly.
I measure the ID of the hole in the points mount and took it to the hardware store and found a suitable one.
Online PeWe
« Reply #2 on: August 06, 2015, 01:05:51 PM »
Search for Rubber Grommets and see if you'll find a size that works.
Vulcanizing tape might be an alternative. Good to have in the toolbox.
« Reply #3 on: August 06, 2015, 01:32:36 PM »
Thanks for the replies.  Does anyone happen to have the ID and OD specs for this grommet?  Surely one of adequate size is available.  It would be easier if I had one in hand to take to the "grommet" store.
« Reply #4 on: August 09, 2015, 06:32:11 PM »
When I find a good fit, I will pick up a few in case anyone else is in need.
