Author Topic: my first bike build, 1977 CB750K  (Read 6995 times)
Re: my first bike build, 1977 CB750K
« Reply #25 on: July 22, 2016, 07:19:00 AM »
Following  :)
Offline 540nova
« Reply #26 on: July 22, 2016, 07:43:46 AM »
I understand your concern, I too read all about the firestones before I bought them. I live 10 minutes from work on a straight smooth hwy in a small town with a speed limit of 35mph. I should be fine.
So you're building this bike to only ride 10 miles @ 35 mph? C'mon. Lose those tires! Seriously.
Offline apope930
« Reply #27 on: July 22, 2016, 08:12:57 AM »
Yep, just to ride around town.
1977 CB750K
Offline 540nova
« Reply #28 on: July 22, 2016, 08:17:34 AM »
Well, I agree about those hipster tires, not suitable for spirited riding. Some Continental Road Attack tires would look and work great. Other than that, great looking bike.
1974 CB450, 2006 CBR1000RR
« Last Edit: July 22, 2016, 08:19:16 AM by 540nova »
« Reply #29 on: July 22, 2016, 08:35:45 AM »
Do you have an exhaust hanger bracket to help support the weight of the pipe? Your pipe might not seem too heavy, but with riding forces (especially the up and down over surfaces) it will place a lot of strain on the exhaust ports of the head.
Offline apope930
« Reply #30 on: July 22, 2016, 09:08:15 AM »
I thought about the same thing, I'll make a bracket that utilizes the clamp holding the megaphone on and just bolt it to the bottom engine mount maybe. Haven't had a chance to sit down and think about all of my options yet.
1977 CB750K
« Reply #31 on: July 22, 2016, 11:21:32 AM »
Good idea.
Offline apope930
« Reply #32 on: August 06, 2016, 01:55:34 AM »
Little progress, I finally got the bike out of the woods and into my garage. Dropped the DOHC swing arm off at my machinist to build some bronze bushing to correct the length on the pivot tube. Installed the rear sets. Cleaned up the engine a little. Installed the SS Allen head hardware. Built the oil pressure gauge thing and de-tabbed the rear section of the frame. Also scored a Cognito Moto upper triple tree for $50
« Last Edit: August 06, 2016, 02:00:46 AM by apope930 »
1977 CB750K
Offline apope930
« Reply #33 on: August 06, 2016, 11:41:03 AM »
Also picked up this seat from dime city cycles. However I personally think it's too narrow for the frame and I'm gonna have a hellva time mounting it.
1977 CB750K
« Reply #34 on: August 06, 2016, 12:12:55 PM »
The DCC/Motolanna seat will work just fine on either a 750 or 550.  You can weld tabs onto the frame rails and then bolt your seat into place.
You can make them or buy them for $20.  http://www.lossaengineering.com/products/lossa-seat-tab-kit
Offline apope930
« Reply #35 on: August 06, 2016, 12:47:20 PM »
That's what I was hoping for but the bolt holes are centered directly above the frame. I need them to be offset inside the rails and the tabs would work.
1977 CB750K
« Reply #36 on: August 06, 2016, 02:54:31 PM »
You could drill mounting holes into the frame rails.
Offline apope930
« Reply #37 on: August 20, 2016, 06:03:27 PM »
So I started to wire up the bike using the simplified wiring diagram however the bike still isn't turning over. Ik my grounds and nice and clean. I am getting 12v out of the teal/red wire going to the neutral safety switch and I think that has something to do with it but I'm a amateur at this. You can see in the factory harness I have arrows pointing to the wire and the diode it ran too that I deleted. Any input on this would be appreciated.
-Allen
1977 CB750K
Offline apope930
« Reply #38 on: August 21, 2016, 05:13:27 AM »
Stripped down the factory harness, the wire I'm inquiring about is bolted directly to the engine with the Phillips head screw pictured above. It is under the transmission cover.
1977 CB750K
