Hey everyone,
I was just reading through a bit of the electrical FAQ, looking at some part #s and a thread on the wiring harness for these bikes, as I just acquired a 1975 CB550 K1 and it seems to make a pezo-like noise (buzz) when I turn the blinkers on (either right or left), but the running lights up front (blinkers, headlight) work, along with the brake light but the rear signals do not even turn on when the running lights are on.
I figure at this point, I've got more than one issue, as I've got the tank off, sides removed, and the headlight out and when I move the nest in the headlight, things either dim, turn off completely, etc., before going back to the normal (broken as described above) running lights. So my question is--how well do these harnesses clean up, I was reading about it in the FAQ, but if there's broken wires, etc. I'm thinking a new wiring harness may just save me a headache. However, I also do not know what that pezo-buzz is, and figure that might be something else someone knows about?
I found this:
http://www.partzilla.com/parts/detail/honda/HP-32100-374-000.htmlwhich doesn't seem too unreasonable, but I'm not 100% sure it's the right part. Any help/insight would be appreciated, even it's just buy the new harness and get it over with
