Author Topic: A/F mix for power  (Read 2048 times)
Offline flatlander
A/F mix for power
« on: August 13, 2015, 05:55:26 AM »
here's the dyno graph for my 550:
the A/F mixture is between 12 and 13 throughout the rpm range. this is where i was also before the current engine mods but i wonder if this is good, or if it can be improved for squeezing a bit more power out of it?
what's done on the engine:
wiseco 59mm pistons
mike rieck stage 2/3 with +1mm intake valves
megacycle 126-00 cam
stock 069a carbs with stock jetting
stock airbox with stock paper filter
more details here: http://forums.sohc4.net/index.php/topic,134863.0.html
Offline TurboD
Re: A/F mix for power
« Reply #1 on: August 13, 2015, 07:25:39 AM »
My experience on track is that around 12.5 to even 13.2 is where you make the most power and best ET. So I would say you're really good.
Offline flatlander
« Reply #2 on: August 14, 2015, 01:41:15 AM »
thanks, that's good to know.
« Reply #3 on: August 14, 2015, 04:27:12 AM »
Roughly 13:1
Offline Bill/BentON Racing
    • BentON Racing
« Reply #4 on: August 14, 2015, 04:41:05 AM »
Samauto on the dyno!! ;D Always liked this pic! K, Bill
BentON Racing Website
BentON Racing Facebook
Offline flatlander
« Reply #5 on: August 14, 2015, 01:36:45 PM »
i guess i could try getting it a tad richer, closer to 13. but that is a really small adjustment. any guesses on how to get there, with jets or needle adjustment?
Offline TurboD
« Reply #6 on: August 14, 2015, 02:38:37 PM »
If you are wanting to richen during WOT, you would install a larger main jet.
« Reply #7 on: August 14, 2015, 05:37:28 PM »
Unless I am seeing incorrectly you are just a bit rich now at 12:1
Online scottly
« Reply #8 on: August 14, 2015, 06:08:03 PM »
The A/F ratio means the parts of air, by weight, to 1 part fuel. A larger number is more air, so 13:1 is leaner than 12:1.
Offline flatlander
« Reply #9 on: August 14, 2015, 11:24:21 PM »
ah yes, thanks for setting me straight.
« Reply #10 on: August 15, 2015, 07:51:38 AM »
Try a K & N air filter for better flow. May lean it out that little bit.
Offline flatlander
« Reply #11 on: August 15, 2015, 08:51:16 AM »
does.k&n still make them for the 550? i mean the one replacing the original filter, not the pods.
