Author Topic: Coils  (Read 1045 times)
Offline ajdsad
  • 1973 CB750 K3
Coils
« on: August 21, 2015, 10:49:58 PM »
I have a '73 cb750 that I couldn't get to start back in late May. I finally had some time today and take a look at it. I'm thinking my coils are bad but how do I confirm this?  I pulled the 1 and 2 plugs and tried to see if it would arc against the engine. I didn't see any arc. I also checked to make sure I was hot to the coils which I am. Any suggestions?
Re: Coils
« Reply #1 on: August 22, 2015, 12:31:17 AM »
« Last Edit: August 22, 2015, 12:33:05 AM by PeWe »
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: Coils
« Reply #2 on: August 22, 2015, 05:27:47 AM »
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline ajdsad
  • 1973 CB750 K3
Re: Coils
« Reply #3 on: August 22, 2015, 07:37:00 AM »
I'll check them out. Thanks guys.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Coils
« Reply #4 on: August 22, 2015, 08:34:33 AM »
Check your ignition system while you're at it, whether it be points/condensers or electronic ignition. I would not expect both coils to fail at once, I would suspect ignition components, ignition wiring, or ignition settings (i.e. points gap). Have you inspected the ignition to confirm it is properly set up and properly connected?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: Coils
« Reply #5 on: August 22, 2015, 10:39:53 AM »
I will bet $50 your coils are good.  How old are your points?
Offline Johnie
Re: Coils
« Reply #6 on: August 22, 2015, 11:19:39 AM »
Tuning in...going through the same issue with my current 750K3 project. I to have never had a 750 coil fail so am checking on other ignition issues.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
