Thanks!! Looking forward to yours getting done.
I think i finally solved the problem. The only thing i never did was change the plugs.
The previous owner told me he had done that less than 1000km ago. So I decided to do it anyway, it's only $10 after all. Also, the bogged carbs obviously fouled the plugs.
So david Silver sell the DR8ESL for our bikes. Now I have read conflicting stories regarding the difference, the R being resistor plugs that should actually be used only with new resistor-less plug caps, and the D8EA that should be used (and were removed today), but the DR8ESL were the only ones available from the bike shop and OMG what a difference. She runs like a rocket now.
I should probably get the stock D8EA eventually, but I don't even know if these caps have resistors in, unless someone with knowledge can tell me otherwise. Or if someone has cut one open to show me. Wait, one of my plug caps are broken, I will cut it open and post the photo here.
I have done the "resistor removal/ replace with brass rod" mod on my CX500, but they actually have resistors, an aluminium rod, and springs that can be removed. I don't see that in the CB400 caps.
Here is a pic of the plugs I removed. From left to right, 1 to 4. Notice no.3 is BLACK.
Stay tued for the cut open plug cap.
