Author Topic: Frame color  (Read 1589 times)
Offline beemerbum
Frame color
« on: August 24, 2015, 08:32:15 AM »
What is the appropriate type of black paint for the CB 750 frame? Where can a guy get it?
Offline lrutt
Re: Frame color
« Reply #1 on: August 24, 2015, 08:39:20 AM »
I've found that the Rustoleum gloss black is perfect. Not too glossy, cheap, and tough enough for frame work. Have used this on many many bikes.
Offline grepper
  • Busted Knuckles
Re: Frame color
« Reply #2 on: August 24, 2015, 09:07:10 AM »
I went with a satin black powdercoat.
Offline Powderman
Re: Frame color
« Reply #3 on: August 24, 2015, 09:43:32 AM »
Most use a 55% PACCAR Black, commonly referred to as "Chassis Black". It's glossier than a satin , but less glossy than a Gloss Black would be.
Offline beemerbum
Re: Frame color
« Reply #4 on: August 24, 2015, 09:57:05 AM »
Thanks for the info. I'm not wanting to powdercoat. I realize its a tough finish. However, I want to keep the VIN  plate on the headtube intact. On a Yamaha tracker I built, the plate was destroyed in the baking process of powdercoat. Fortunately, the VIN is also stamped into the headtube. It was legible (barely) under the powdercoat.
Offline Powderman
Re: Frame color
« Reply #5 on: August 24, 2015, 01:53:38 PM »
Who was the dumb ass that left the plate on there. Remove it for powder coating. It's only 2 rivits that hold it on. Unfortunately for every one of us reputable coaters out there, there are 6 hacks just destroying the business by not knowing what they are doing. 400*F should have no effect on the stamped VIN plate.
Re: Frame color
« Reply #6 on: August 24, 2015, 02:12:50 PM »
The original "look" of the frames was around 60% gloss until 1974, when it became a mild gloss finish on all of the Fours.
Re: Frame color
« Reply #7 on: August 24, 2015, 04:25:38 PM »
 +1 on Rustoleum Black. Nice color, cheap and easy to touch up.
Re: Frame color
« Reply #8 on: August 24, 2015, 06:51:05 PM »
I have found that, if you intend to ride your bike a lot and in all weather, full gloss is the way to go.  Perhaps too shiny at first, but after several cleanings it dulls up a bit and ends up just right.
Offline beemerbum
Re: Frame color
« Reply #9 on: August 24, 2015, 08:17:20 PM »
Unlike the Honda plate attached with rivets, the Yamaha has a vinyl sticker that cannot be peeled off without destroying it.
Re: Frame color
« Reply #10 on: August 25, 2015, 01:24:03 AM »
Replacements may be available ...
http://www.ebay.com/itm/PLAQUES-CONSTRUCTEUR-YAMAHA-VIN-plates-YAMAHA-/301542183527?hash=item4635509267
Re: Frame color
« Reply #11 on: August 25, 2015, 03:22:12 AM »
I am very happy with Majic paint brand, sold at TSC.  I used full gloss on the frame, looks good and the quality is excellent since it is implement paint.
Re: Frame color
« Reply #12 on: August 26, 2015, 09:41:12 PM »
 Black Rustoleum appliance epoxy in the big spray can.
