That's quite an improvement. How are you mounting it? Are you welding in a hoop or new crossmember to prevent frame twist?
What did you use to clear the tank? 2k urethane clear with UV stability? I really like the tank's finish, it really is interesting and should pop in good bright sunlight. Looks great! I too would want a loop or other support beneath the seat and something to anchor taillights and turn signals to.
Wow thank tank came out great. Funny how a Massachusetts bike ended up all the way in the Netherlands. I am guessing it was bought in during the Bettencourt bike auction a few years back.
hi, welcome from another inhabitant of this kikkerlandje. whereabouts are you?an "old" style blue number plate would look good there. don't know if you're able to get it for your bike, but may be worth a try.are you aware that wrapping your header pipes does more harm than good? your call - just want to make sure you're aware as many people seem to fall for the looks without thinking about consequences.
You could coat the exhaust prior to wrapping, but then there'd be no need to wrap it. I'm not a huge fan of exhaust wraps, myself. I've heard they are a PITA to install (right) and leave you with gnarly fiberglass itch.
nice pictures!before changing parts you can test for the air leak with a spray can of wd-40 or carb cleaner: while your engine is idling, spray where you suspect the leak. when you hit the spot where the leak is, the engine sound changes.
