Well I was so encouraged at how fantastic I had it running as far as riding it goes, that I thought I could get it to idle better too. Leaning out the idle screws didn't cut it- it was still rich at idle, so I took out the #38 pilots and put the #35's back in. I am now 100% happy with it - it starts first kick, idles well and has no flat spots. It will happily pull from as low as 1100rpm (although naturally I don't suddenly snap the throttle wide open from such low revs!). At high revs with a big handful of throttle the clutch is now prone to occasionally slipping again so the power's definately back. p.s. I got the order wrong by doing the pilots before the needle clips as the needle clips then affected the pilot circuit and so yes I did some tail chasing.
I of course want to fix the low compression eventually, but there was no way I was about to put money into new rings until I had a properly functioning set of carbs for the bike first and it goes so well that I am still in no hurry. I want fuel, electical, brakes, etc, etc all 100% sorted before I take the engine back out to rebuild it. Then when It comes to bedding in/running in the new rings I wont have any dramas interfereing with the process of running in my newly rebuilt engine!! p.s. I have only done one compression test on this engine and it was way back when I had only just picked it up from the local wrecking yard where it had been sitting under a pile of engines at the back of the shed for probably 20-30 years, and I had only ridden it ~100 miles. I expect the compression may have improved since then with the over 1300 miles that I have on it now, but it does use oil and I do conceed that the low compression may cause it to run a little richer than otherwise...
Below is a picture of the emulsion tubes that have given me so much trouble, see how big the holes are?- the 069A tubes have much, much smaller holes! Thanks to harisuluv for pointing out that 069A carbs have different emulsion tubes as that was the turning point for me (well that and finding an airbox snorkel and realising that I dont have to remove the carbs from the bike to remove the slides or take off the float bowls).
Below that is a picture of the 069A parts carbs I scored cheap off ebay from Phillip island Australia! You virtually never see SOHC carbs on ebayAustralia, and I took a punt that I might get some good bits from them -and well this was a fantastic stroke of luck- although battered and rough on the outside, they had 100% original brass and seem quite clean and unmolested inside with no wear or damage at all that I can detect. They cost me less than ONE new oem needle jet set and that's if I could even find any for sale! Bargain!
The slides below the carbs are the ones I took out of the bike which have the suspiciously shiny needles in them, the slides, needles, emulsion tubes and idle screws out of the those carbs are now in the 627B carbs in the bike.
Recap- With the correct needle jets(emulsion tubes), and the airbox cover fitted, it now runs perfect with almost stock settings:
mains #98, 069A needles clipped #2, 069A needle jets, pilots #35, 069A solid idle screws 1 turn out,
original air filter witrh snorkel, original 4 into 1 with aftermarket straight through muffler.
John
